Donflem Posted October 10, 2021 Share Posted October 10, 2021 So my 10k generator is running weird and I think has a smell. It’s charging ok just Fluctuates I was like maybe it’s not idling fast enough. I’m in Bullhead city Nevada but I can’t find nobody here to work on it so I’m going to head up to Vegas on Monday any recommendations on who to take Cummins generator to in Vegas. I’m full time so I need to find somebody take a look at it right away any help would be appreciated. Thanks Don 2007 Monaco dynasty Link to comment Share on other sites More sharing options...
Ivan K Posted October 10, 2021 Share Posted October 10, 2021 Your 10k, just like our 12.5 is a constant RPM system, whether loaded or not, it should run at the same speed. I could imagine that the front armature bearing might be seizing and slowing the motor down. The noise would be coming from the very front of it. If it was the case, you should get it serviced quick because once the whole bearing, including its race starts spinning, it will burn the oring it sits in and eat into the metal centering support which may or may not be available these days. There is a Cummins dealer in Las Vegas but I only visited them for parts, no experience with their labor. Link to comment Share on other sites More sharing options...
Donflem Posted October 10, 2021 Author Share Posted October 10, 2021 Thanks Ivan. I’m going to drive to Vegas in the morning and see if I can find someone to look at it. I think the smell I’m smelling might be Aqua hot fluid I noticed my aqua hot reservoir is empty, so I need to check that for a leak and then find some fluid to put back in it. I love the smell of broken motorhome stuff in the morning lol. Link to comment Share on other sites More sharing options...
