Ron Shantos Posted January 23 Share Posted January 23 In the process of replacing the light bulb in the "Goose Neck" Map Light (per label on the positive wire) I blew the fuse to the MAP light. I have checked every fuse in the electrical bay and all are good. I can find nothing else electrical on the dash that does not work. Any ideas appreciated. Ron Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted January 23 Share Posted January 23 Some coaches have a 12 vdc fuse panel in the bedroom. Link to comment Share on other sites More sharing options...
Corkman Posted January 24 Share Posted January 24 On my 2001 Dynasty, you turn the drivers gooseneck light on by using the headlight switch and rotate it all the way left until it clicks. Link to comment Share on other sites More sharing options...
Ron Shantos Posted January 24 Author Share Posted January 24 Bill, This is a goose neck/flexable map light located on the driver side console, not the ceiling overhead map light. The one in the ceiling works properly but rotating the headlight switch on the dash. Thanks, Ron Link to comment Share on other sites More sharing options...
Poppa G Posted January 24 Share Posted January 24 On our 2003 HR Imperial,drivers front side basement door it contains fuses there is a black cover unscrew the three plastic wing nuts to re move cover,on the back of that cover should have fuse diagram,if you look closely you should see on the fuse panel showing for map lights and goose although it doesn’t say goose neck,don’t know if that will help,but most Monaco rigs are pretty much the same,not saying they are but give it a try. Link to comment Share on other sites More sharing options...
Ron Shantos Posted January 24 Author Share Posted January 24 Thanks Gary, I will check this. Link to comment Share on other sites More sharing options...
Corkman Posted January 24 Share Posted January 24 41 minutes ago, Ron Shantos said: Bill, This is a goose neck/flexable map light located on the driver side console, not the ceiling overhead map light. The one in the ceiling works properly but rotating the headlight switch on the dash. Thanks, Ron Ron, I was talking about a gooseneck flexible map light located on the driver side console. I thought that’s what I said. I don’t have one in the ceiling. Link to comment Share on other sites More sharing options...
Ivan K Posted January 24 Share Posted January 24 Like Chuck mentioned, even though our coach is years older, our gooseneck map lights share a fuse with door handle in bedroom 12v fuse box. Link to comment Share on other sites More sharing options...
Ron Shantos Posted January 24 Author Share Posted January 24 When you say door handle, are you talking about the LIGHT in the door handle? Just for information, the gooseneck map light at the passenger seat console works. I don’t recall ever seeing a 12v breaker box in bedroom. I will look for one. Thanks Link to comment Share on other sites More sharing options...
Corkman Posted January 24 Share Posted January 24 My drivers gooseneck map light works off the headlights switch as I mentioned. My wife’s passenger gooseneck does not work on that same headlight switch. Link to comment Share on other sites More sharing options...
Ivan K Posted January 24 Share Posted January 24 12 hours ago, Ron Shantos said: When you say door handle, are you talking about the LIGHT in the door handle? Just for information, the gooseneck map light at the passenger seat console works. I don’t recall ever seeing a 12v breaker box in bedroom. I will look for one. Thanks Yes, I mean a door handle light. Our interior 12v fuse box is in the last driver side bedroom overhead cabinet, cut into the rear wall. Since we are years apart, likely not the same as yours. Just an idea. Link to comment Share on other sites More sharing options...
