Bjohnsonmn Posted March 9, 2022 Share Posted March 9, 2022 I am redesigning the electrical system in our 2000 Windsor 32PB, including how the 110v system works. Our coach has the generator and shore power run to the central basement (interrior) where the transfer switch is. This is also where the inverter/charger is located to. The 110 wiring goes from the transfer switch to the main panel. Then, a smaller gauge wire runs from the main panel back to the power basement to the inverter, then back to the inverter 110 sub panel in the rear. My plan is the run the transfer switch output to the Multip-plus II, then use the runs back to the 110 panels to power the pannels, removing the return romex from the mix. Ill also be taking the inverter breakers out of the main panel. The Multi-plus II has the ability to handle 50amp split phase in an impressive manner. My challeng is that the wire from the transfer switch to the main panel is about 1'-2' too short. Given that it is 110/240, I believe Polaris connectors are the right way to extend these if I am unable to re-run the wire. This is an internal cavity with no access to the outside except a slide over panel in the passthrough. Any experience with this? Thanks! Link to comment Share on other sites More sharing options...
CorinthWest Posted March 9, 2022 Share Posted March 9, 2022 I'm no electrician, but I HATE the romex they use in these coaches (and anywhere else). When you look up "cheap" in the dictionary, you'll see a picture of romex cable. I've strung plenty of wires, and I ALWAYS use flexible metal conduit. Best thing since sliced bread. You can even get it pre-strung with wire. But then that's just my personal preference. That and a quarter won't get you a cup-o-java. Link to comment Share on other sites More sharing options...
JDCrow Posted March 9, 2022 Share Posted March 9, 2022 I’ve done exactly what your wanting to do. But pulled the romex out and ran longer. My coach is obviously different set up. But I used carflex 1” and drilled a few holes to run it so romex was protected. Also added a lithium battery and Dc/Dc charger 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted March 9, 2022 Share Posted March 9, 2022 55 minutes ago, Bjohnsonmn said: I am redesigning the electrical system in our 2000 Windsor 32PB, including how the 110v system works. Our coach has the generator and shore power run to the central basement (interrior) where the transfer switch is. This is also where the inverter/charger is located to. The 110 wiring goes from the transfer switch to the main panel. Then, a smaller gauge wire runs from the main panel back to the power basement to the inverter, then back to the inverter 110 sub panel in the rear. My plan is the run the transfer switch output to the Multip-plus II, then use the runs back to the 110 panels to power the pannels, removing the return romex from the mix. Ill also be taking the inverter breakers out of the main panel. The Multi-plus II has the ability to handle 50amp split phase in an impressive manner. My challeng is that the wire from the transfer switch to the main panel is about 1'-2' too short. Given that it is 110/240, I believe Polaris connectors are the right way to extend these if I am unable to re-run the wire. This is an internal cavity with no access to the outside except a slide over panel in the passthrough. Any experience with this? Thanks! Put a junction box at the connection to keep it protected and meet code. Don't mess with the grounding wire. Don't want to electrify the body. Gary 05 AMB DST 2 Link to comment Share on other sites More sharing options...
Gary Cole Posted March 9, 2022 Share Posted March 9, 2022 (edited) 58 minutes ago, CorinthWest said: I'm no electrician, but I HATE the romex they use in these coaches (and anywhere else). When you look up "cheap" in the dictionary, you'll see a picture of romex cable. I've strung plenty of wires, and I ALWAYS use flexible metal conduit. Best thing since sliced bread. You can even get it pre-strung with wire. But then that's just my personal preference. That and a quarter won't get you a cup-o-java. I agree. Solid conductor romex is barely adequate for a house. Much less a moving vibrating vehicle. I have replaced every 15/20 A romex cable which I have access to with mc cable w/ stranded conductors including any new wiring projects. I no longer follow the code however as I understand it many local authorities no longer adopt the NFPA article relating to RVs so NFPA 551 no longer applies. Which means that there is no applicable NEC code as applied to RVs. Maybe someone here knows more about it. If so heavy duty oil/water resistant 12 ga, fine strand conductor ( machine tool rated designed for flexibility), extension cord would be my first choice. Available at your neighborhood hardware stores everywhere and cheap. Let me find my sunglasses before I get flamed. 😄 Edited March 9, 2022 by Gary Cole 1 Link to comment Share on other sites More sharing options...
windsorbill06 Posted April 21, 2022 Share Posted April 21, 2022 (edited) I see another thread running on same subject. Edited April 21, 2022 by windsorbill06 duplicate post Link to comment Share on other sites More sharing options...
