mschfmkrs1 Posted March 17, 2022 Share Posted March 17, 2022 2004 Signature Castle III, 45’ Series 60. Drivers side headlights work, passenger side has no power and bulbs are good! Any suggestions would be appreciated. Thank you, Ed H. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted March 17, 2022 Share Posted March 17, 2022 We have the same problem except neither of our headlights work. Our coach had been at Lazydays (Tampa) for two months now to get this problem resolved and fixed. Must be a really hard job, huh? Link to comment Share on other sites More sharing options...
powersltc Posted March 17, 2022 Share Posted March 17, 2022 5 minutes ago, Tom Whitlow said: We have the same problem except neither of our headlights work. Our coach had been at Lazydays (Tampa) for two months now to get this problem resolved and fixed. Must be a really hard job, huh? Ron P. 2004 Monaco Executive I had a similar problem withmylights. Don't remember which low beam or high beam but i couldn't get pass inspection. Replaced the controller, , etc.. I took it to a heavy truck repair shop. . The repair shop rigged up something that causes me to now have daylight running lights for my low beam and high beam work as normal. We it turn the key or turn the coach on the lights come on. Link to comment Share on other sites More sharing options...
vito.a Posted March 17, 2022 Share Posted March 17, 2022 James Voyles sent me a headlight schematic. His drawings are much better than the original Monaco drawings. Hope this helps! Headlights, Run, Clearance, Fog and Dash- Schematic.pdf Link to comment Share on other sites More sharing options...
mschfmkrs1 Posted March 18, 2022 Author Share Posted March 18, 2022 Tom Whitlow, sorry they’ve had your coach for so long, but it definitely should not take much time to correct the problem. POWERSLTC, thank you for the information, sounds like you got your monies worth. Vito, thank you for sharing the headlights schematic. I will check it out and let the group know how it goes. Thank you all, Ed H. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted March 18, 2022 Share Posted March 18, 2022 A wiring work-around just to have headlights (safety issue?) on a high end motor home. Unbelievable. Link to comment Share on other sites More sharing options...
mschfmkrs1 Posted April 6, 2022 Author Share Posted April 6, 2022 NO POWER TO PASSENGER SIDE HEADLIGHTS - Fixed!!! Removed circuit board for passenger side headlights. Soldered jumper wire from the power supply on the back of the board to the right hand relay and all lights work again, as they should. 2004 Monaco Signature 45’ Castle III Ed Link to comment Share on other sites More sharing options...
