Posted
ordered pump switch rtl30a18v for the water pump it lookes like the replacement switch it is on-off-on but need a momentary-off-momentary does ant one have the correct part number or a scorce for this switch.
Thanks Mike
Posted
Thanks Mike
Most likely a Sigma or Carling.  Sigma are the smaller and Carlings have a larger bezel for mounting over the panel.  This is a garden variety switch.  Other than aesthetically wanting an exact match, any that snap in will work.  You do not say whether you have a lighted switch or an plain one….which would then have an indicator light nearby to show the pump was running or off.
Try this one.  They are Internally lighted…
https://shop.findmyrvparts.com/monaco-rv-water-pump-switch-momentary-S16614110-p/190187.htm
NWRV has the same switch with several part numbers….
http://www.nwrvsupply.com/product/DG44A28VP.html
Basically you need to look at the back of the switch.  If you have 3 terminals in a row, then the switch will work…but make sure that you mark the wires TOP, MIDDLE & BOTTOM.  The other two wires are for the neon or LED indicator light…the NWRV schematic is a bit confusing and I understand how the switch works and how to wire it.
Good Luck.
Posted (edited)
Mike, you didn't post the year, make and model coach you presently have so it's a crap shoot as to exactly what you are looking for other than needing a momentary switch. Photos help too!
The switches that Tom has pointed out to you fit into a much different bezel shape than the Carling Technology Switches or the SIgma Switches. The green ones are squarish whereas the two that I suggested are rectangle in shape.
Here are two links other choices.
Black Dual Momentary On/Off/On Switch 12v: nwrvsupply.com
Single Momentary Blank Switch V2DA: nwrvsupply.com
Not sure exactly what you need for your application but now you have other choices,
Edited by Dr4Film
Posted
The switch that Tom suggested is the exact correct one for your application. They must have changed to the rectangle ones in newer coaches.
Also, I totally missed your bio information on the left as to your coach, etc. I normally see it in the signature lines below the post.
  • 1 month later...
Posted
Thanks Mike
Ordered it, thanks again guys. Love this site.
