Crooked slide
Push the slide end that does not go in to be flush. May need some helpers and open the t-handles on hydraulic valves. Then close the valves and block the slide from inside if it doesn't have locks. I drove like that from Canada to TX. If you can DIY, pull the leaky cylinder and have the seals replaced at any hydraulic shop. Nothing special about it. Could also be just a fitting leak if not a hose leak.
  • Thanks 1
