NGADawgs Posted July 9, 2022 Share Posted July 9, 2022 (edited) On a recent trip to Florida the generator did a code 36 shutdown several times. It was possibly a vapor lock from my subsequent research. It appears to be related to the fuel pump. It is probably original from 2007 so I decided that I would replace it. I spent several hours the other day trying to find the correct fuel pump for my generator. Many people suggested the Airtex E11020 but I couldn't find one of them available... I also searched for these Onan part numbers, 149-2790 and A047N931 and was able to locate one through a liquidator on Ebay. The picture on the Ebay ad showed the correct (but old) part number as 149-2790. However, upon receiving it today, the one I received did not have that part number on it...instead it had some foil labels applied over the original label so I couldn't read it. It does say "12VDC 3-6 PSI" on the label. In all of my research including on Cummins Quickserve, I can't find the specifications on the PSI for the OEM fuel pump. Does anyone know that? Also, has anyone added an inline fuel pump located near the fuel tank? I have read that some did that to reduce vapor locks. Thanks in advance for the input! Edited July 9, 2022 by NGADawgs Link to comment Share on other sites More sharing options...
dandick66 Posted July 10, 2022 Share Posted July 10, 2022 I’ve never hear of a Diesel engine getting vapor lock - maybe I’ve lead a sheltered life. Looking at the picture of the fuel pump you bought, that is a universal inline fuel pump. I hope you didn’t pay a lot for it. They can be found all day on Amazon and eBay for anywhere from $10 on up. You do want to mount the pump as close to the tank as possible. Have you checked the fuel filter? Link to comment Share on other sites More sharing options...
NGADawgs Posted July 10, 2022 Author Share Posted July 10, 2022 The fuel filter was changed about 20 hours ago. I will check that when I get ready to open it up. Link to comment Share on other sites More sharing options...
Twomed Posted July 11, 2022 Share Posted July 11, 2022 That looks like an Airtex that was relabeled. 3-6 is all it takes to run the gen. You are lucky the original lasted this long. They are a made in Mexico item. I have replaced mine a couple of times, but have 4,600 hours on the gen. Always carry a spare because they usually fail in high temp or high altitude cold environs. Lots of fun changing then 😬😬 PS...usually get a code tha says change $600 control board...always change fuel pump first! Link to comment Share on other sites More sharing options...
gofastnow Posted August 22, 2022 Share Posted August 22, 2022 On 7/9/2022 at 5:57 PM, NGADawgs said: On a recent trip to Florida the generator did a code 36 shutdown several times. It was possibly a vapor lock from my subsequent research. It appears to be related to the fuel pump. It is probably original from 2007 so I decided that I would replace it. I spent several hours the other day trying to find the correct fuel pump for my generator. Many people suggested the Airtex E11020 but I couldn't find one of them available... I also searched for these Onan part numbers, 149-2790 and A047N931 and was able to locate one through a liquidator on Ebay. The picture on the Ebay ad showed the correct (but old) part number as 149-2790. However, upon receiving it today, the one I received did not have that part number on it...instead it had some foil labels applied over the original label so I couldn't read it. It does say "12VDC 3-6 PSI" on the label. In all of my research including on Cummins Quickserve, I can't find the specifications on the PSI for the OEM fuel pump. Does anyone know that? Also, has anyone added an inline fuel pump located near the fuel tank? I have read that some did that to reduce vapor locks. Thanks in advance for the input! This is a stretch, but let me tell you about my blocked fuel tank vent hose. Was going on a long trip in middle of summer running both ACs and the gen would shutdown about every 20 minutes and would start back up after a while off. Did not affect the coach engine's running, purred right along. Long story short, discovered fuel tank vent hose had a mud dubbers nest in it. Cleared the nest and fixed. Good luck. Link to comment Share on other sites More sharing options...
