Joe E. Posted July 23, 2022 Posted July 23, 2022 2008 HR Ambassador 40SKQ, Cummins ISC-360, DPF, 95K miles. Dash A/C compressor froze up, shredded serpentine belt. Truck repair business sourced and installed new compressor and belt, but that's all. Refrigerant hoses and electrical not connected to new compressor. Need recommendations for A/C service shops in Jacksonville, FL area ( within ~100 miles) to finish the job. Probably need to remove and install new dryer and expansion valve, and the normal evacuate, clean, vacuum, refill, test. If anyone has part numbers for the dryer and expansion valve, that would be very helpful. I will check the parts list.
Ron Shantos Posted July 24, 2022 Posted July 24, 2022 Joe, I have a 2008 Beaver which should be close. I have A SCS system. Model number is by the dryer assembly. Acme Air Parts has most parts. 913/515-1560 ask for Richard. [email protected]. They should have your parts. Ron
Joe E. Posted July 24, 2022 Author Posted July 24, 2022 Thanks Ron. I will give Richard a call. Still need a shop to do the work.
Ivan K Posted July 24, 2022 Posted July 24, 2022 When you find a shop to do it, you may want to tell them what happened to the old compressor. There might be so called 'black death' debree in the system and lines should be flushed to prevent damage to the new one.
