Orrin C Posted August 26, 2022 Share Posted August 26, 2022 I have lost power to the exhaust brake. It is a PAC brake. The switch on the driver's consul, by my left arm, no longer lights up when it is turned on. I have done some poking around but can't find anything. I thought maybe a fuse but can't find one. Does anyone have a wiring diagram for my coach? It's a 2002 HR with the Cummins ISC 8.3 liter and the Allison 6 speed. Thanks in advance. Link to comment Share on other sites More sharing options...
Rocketman3 Posted August 26, 2022 Share Posted August 26, 2022 My 2000 Dynasty has a 10a fuse in the front electrical bay. Link to comment Share on other sites More sharing options...
Orrin C Posted August 26, 2022 Author Share Posted August 26, 2022 Rocketman, thanks for the reply. Is the fuse numbered? I have searched through the front electrical bay and can find no fuses labeled exhaust brake. I have found in the rear electrical bay a bunch of relays labeled exhaust brake. No breakers or fuses found there. I have no idea how to trace the wires without a diagram. Link to comment Share on other sites More sharing options...
jacwjames Posted August 26, 2022 Share Posted August 26, 2022 9 hours ago, Rocketman3 said: My 2000 Dynasty has a 10a fuse in the front electrical bay. I have the Monaco 1 & Monaco 2 fuse boxes in my front drivers side run bay. The #2 box has a 20 amp fuse in it along with a relay. Other area to check is in the engine compartment where the PacBrake is, there is a solenoid back there that send air to the pacbrake. 1 Link to comment Share on other sites More sharing options...
Orrin C Posted August 27, 2022 Author Share Posted August 27, 2022 Thanks for the replies. I have wire diagram book from: nwrvsupply.com86325 College View RoadEugene, OR 97405USThey print these books to order. Also, they are not cheap. I paid $125 plus shipping for one for my MH. I let you know how it works out and how good the book is. 1 Link to comment Share on other sites More sharing options...
jacwjames Posted August 27, 2022 Share Posted August 27, 2022 (edited) In the Downloads section under Electrical there is are wiring diagrams for a 2002 Knight/Ambassador. Back ~8-9 years ago when Monaco still provided tech support for our rigs I requested a set of electrical diagrams for house and chassis and they sent me the set for free. The benefit of having a PDF copy is that I can use the search function for key words. Also can zoom in and the then print screen view, especially helpful with the chassis diagram which I have to zoom 1200% to be able to see. I can then save this view in my files for future reference. These files I got from Monaco where then uploaded to the Downloads section by one of the moderators. Edited August 27, 2022 by jacwjames Link to comment Share on other sites More sharing options...
lake49068 Posted August 27, 2022 Share Posted August 27, 2022 Previous coach was a 1998 Endeavor with ISB engine. Had a blown fuse in early 2000's and HR/Monaco tech service said to increase fuse by 5 amps...don't remember what the factory installed amperage was. Fuse was in FRB, followed their recommendation and had no more issues through 2010 trade in. Link to comment Share on other sites More sharing options...
Orrin C Posted August 29, 2022 Author Share Posted August 29, 2022 Jacwjames, I downloaded the file you mentioned, I think this will help. It does not seem to be searchable, unless I am missing something. Thank you for the information. Link to comment Share on other sites More sharing options...
jacwjames Posted August 29, 2022 Share Posted August 29, 2022 33 minutes ago, Orrin C said: Jacwjames, I downloaded the file you mentioned, I think this will help. It does not seem to be searchable, unless I am missing something. Thank you for the information. Sorry about that, the file in the downloads is a scanned set so you won't be able to search it. You'll have to do it the old fashion way. Link to comment Share on other sites More sharing options...
Orrin C Posted August 31, 2022 Author Share Posted August 31, 2022 I received the schematic book from NWRVSUPPLY last evening. It appears to be very complete and is in a large format. It is the same as the pdf Jacwjames has refered to. I am pleased with it. Link to comment Share on other sites More sharing options...
jacwjames Posted August 31, 2022 Share Posted August 31, 2022 I assume these are paper copies, too bad you couldn't get a true PDF. I tried to look at the scanned copies but not that good of quality. Can you post a picture of the drivers side electrical bay below the drivers window? Link to comment Share on other sites More sharing options...
