bigbhb Posted August 26, 2022 Share Posted August 26, 2022 Looking for the ground for the Aladdin.the pic comes and goes for the camera and is jumping with lines.That is why I think it is the ground.Any help at all would be appreciated.Sometimes it works fine.thank you.2006 holiday rambler endeavor. Link to comment Share on other sites More sharing options...
myrontruex Posted August 26, 2022 Share Posted August 26, 2022 If you suspect a ground and know what wire it is but just cannot follow it you should be able to substitute your own. Chasing wires is not a lot of fun. A good headlight and patience helps. Sometimes searching after dark with a headlight helps as well. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted August 26, 2022 Share Posted August 26, 2022 13 hours ago, bigbhb said: Looking for the ground for the Aladdin.the pic comes and goes for the camera and is jumping with lines.That is why I think it is the ground.Any help at all would be appreciated.Sometimes it works fine.thank you.2006 holiday rambler endeavor. The Aladdin system consists of modules or components that are tied together via RS485 data busses. Any corrupt data from modules or components can cause your camera to display jumping lines. You need to remove each module or component one by one until the jumping lines go away. Link to comment Share on other sites More sharing options...
Bill R Posted August 26, 2022 Share Posted August 26, 2022 2 hours ago, Chuck B 2004 Windsor said: You need to remove each module or component one by one until the jumping lines go away. Following this thread. Not sure my issue is the same. But my Weldex monitor will be wavy when displaying the Aladdin engine info and cameras when I first start up the engine. Give it about 10 minutes and all lines and waviness goes away. I was thinking that it is just a monitor going bad and needing replacement? Link to comment Share on other sites More sharing options...
