TOBYLB4 Posted September 10, 2022 Share Posted September 10, 2022 Changing my AES switch. Found my grounds on the buss bar, but the bus bar itself is not tied to a ground. Should I run ground out to the frame or can I tie them in with one of the electric junction boxes next to it? Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2022 Share Posted September 10, 2022 (edited) What is an AES switch? Plus, what bus bar are you referring to that isn't grounded? I just Googled a RV AES switch and came up with the following. Never seen one or even knew they existed. Dave's Place - Dometic AES Switch (dave78chieftain.com) Edited September 10, 2022 by Dr4Film Link to comment Share on other sites More sharing options...
TOBYLB4 Posted September 10, 2022 Author Share Posted September 10, 2022 I didn't know either. It switches power between rear a/c and washer that are on the same 20 amp circuit. I burnt mine up running both at the same time. The switch has a buss bar inside the box but it's not grounded to anything. Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 10, 2022 Share Posted September 10, 2022 32 minutes ago, TOBYLB4 said: I didn't know either. It switches power between rear a/c and washer that are on the same 20 amp circuit. I burnt mine up running both at the same time. The switch has a buss bar inside the box but it's not grounded to anything. Please post a picture. The ground bus bar should be connected to the Intellitec AES case. The 3 grounds get connected to that bus bar. There should be a circuit diagram on your Intellitec Automatic Energy Select switch cover. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2022 Share Posted September 10, 2022 Gary, I thought they were called an Intellitec EMS switch but after Googling Intellitec and reading about that specific switch, they also call it AESS, an Automatic Energy Select Switch. Products – Intellitec Products, LLC I learned something today. I have one of those someplace in my coach that controls the Washer/Dryer and Rear AC such that you can only run one or the other, not both at the same time. I plan to change the wiring such that it controls the middle AC and not the rear as we seldom use the middle AC unless it is REALLY hot inside the coach and the two AC's can't keep it comfortable inside. Link to comment Share on other sites More sharing options...
TOBYLB4 Posted September 10, 2022 Author Share Posted September 10, 2022 I have the new switch installed. But the 2nd picture shows the outside of the buss bar with a place to run a ground for the switch. Old switch had no ground to the box. I would think it should be grounded. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2022 Share Posted September 10, 2022 Wouldn't it be grounded back at the main power panel where the Romex wires originate from? Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 10, 2022 Share Posted September 10, 2022 12 minutes ago, Dr4Film said: Gary, I thought they were called an Intellitec EMS switch but after Googling Intellitec and reading about that specific switch, they also call it AESS, an Automatic Energy Select Switch. Products – Intellitec Products, LLC I learned something today. I have one of those someplace in my coach that controls the Washer/Dryer and Rear AC such that you can only run one or the other, not both at the same time. I plan to change the wiring such that it controls the middle AC and not the rear as we seldom use the middle AC unless it is REALLY hot inside the coach and the two AC's can't keep it comfortable inside. No extra ground needed. The main cable back to the box is your ground. 13 minutes ago, Dr4Film said: Gary, I thought they were called an Intellitec EMS switch but after Googling Intellitec and reading about that specific switch, they also call it AESS, an Automatic Energy Select Switch. Products – Intellitec Products, LLC I learned something today. I have one of those someplace in my coach that controls the Washer/Dryer and Rear AC such that you can only run one or the other, not both at the same time. I plan to change the wiring such that it controls the middle AC and not the rear as we seldom use the middle AC unless it is REALLY hot inside the coach and the two AC's can't keep it comfortable inside. Would like to know how you are going to run the AC power cables to load shed the center and not the rear AC unit. I don't think you have access to the center AC from the location of the AESS and you can't run AC powered cables between AC units through the center duct. Link to comment Share on other sites More sharing options...
TOBYLB4 Posted September 10, 2022 Author Share Posted September 10, 2022 Thanks for all the information. Link to comment Share on other sites More sharing options...
Jim Cinalli Posted October 31, 2022 Share Posted October 31, 2022 Can someone enlighten me on where I might find my AESS. Lost power to rear AC. 2008 sig bath+1/2 Link to comment Share on other sites More sharing options...
Frank McElroy Posted October 31, 2022 Share Posted October 31, 2022 Look in the cabinet where the house multiplex system is located. It should be near the floor or under the floor if it is a false floor below the house multiplex system. Link to comment Share on other sites More sharing options...
Jim Cinalli Posted October 31, 2022 Share Posted October 31, 2022 Thanks Frank there are two one for the washer and number three air conditioning and one for the dryer and number two air conditioning. I’ll try to send you pictures. Link to comment Share on other sites More sharing options...
Frank McElroy Posted October 31, 2022 Share Posted October 31, 2022 Yep, you found them. Looks like the wires are labeled too. Many folks bypass the AESS by connecting the white wires together and the black wires together and then just remember to turn off the rear AC when doing laundry. A sticky note as a reminder on the washer helps. If you forget, you will trip the CB. 1 Link to comment Share on other sites More sharing options...
TOBYLB4 Posted November 1, 2022 Author Share Posted November 1, 2022 07 Dynasty Queen mine was under passenger side bottom drawer next to closet. Link to comment Share on other sites More sharing options...
