gdroberson Posted September 26, 2022 Share Posted September 26, 2022 Hi all I have two of the atwood windows that slide up in my coach and they had a plastic piece that is screwed to the inside frame that hold the window up when you open it they have broke does anyone know what they are called and where I might find them thank Gary Link to comment Share on other sites More sharing options...
Mark B Posted September 26, 2022 Share Posted September 26, 2022 Pacific North, Manufacturer of Tooling and Outdoor Products DP203.-Red DP-263-Red Dual Pane Window Latch was 633 ) $29.00 each $6.00 shipping $35.00 This was two years ago. Link to comment Share on other sites More sharing options...
gdroberson Posted September 26, 2022 Author Share Posted September 26, 2022 that is the locks the part I need is plastic part that is screwed to the inside track where the window slides so when you open the window it holds the window up so it just dont slide down puts pressure on the side of the window Link to comment Share on other sites More sharing options...
Steve Maurer Posted September 26, 2022 Share Posted September 26, 2022 Try this https://www.nwrvsupply.com/product/atwood-window-latch-dh343ck/ Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 26, 2022 Share Posted September 26, 2022 10 hours ago, gdroberson said: that is the locks the part I need is plastic part that is screwed to the inside track where the window slides so when you open the window it holds the window up so it just dont slide down puts pressure on the side of the window Atwood is not longer a window fabricator. If you do some digging, I think that it was bought by Duncan….then swallowed up by Lippert. In 2018, they were providing new tempered glass for their old frames. They had all the Atwood files and model info and engineering drawings. They also had the magic list of which ATWOOD window was used where in which model. Their shop was in Elkhart. i spent time with the lady that runs it who was an original Atwood manager. I don’t know if they had any “parts”. https://www.rvglass.com/about Try this… Parkin-ACC.com had trouble getting the website to resolve, but here is a link with phone numbers. They “advertise” Atwood Parts. http://parkin-acc.com/Pdf%20RV%20Window%20Check%20List.PDF Good Luck. BTW…a good picture is what NWRV will need….been there. Done that. Link to comment Share on other sites More sharing options...
gdroberson Posted September 26, 2022 Author Share Posted September 26, 2022 thank for all the help Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 26, 2022 Share Posted September 26, 2022 37 minutes ago, gdroberson said: thank for all the help Update. The 3M VHB will definitely hold….as in almost “weld” the frame. I think that the original installation was with a thicker, butyl rubber double stick tape. Amazon sells it. EternalBond also makes a double stick tape for RV use. It is on Amazon as well. Might have to trim it or cut it to the right width. Do NOT be surprised if one corner is really tight. Monaco’s fabricators were sometimes sloppy with the cutout pattern. The assemblers all had big rubber mallets. I had a shop with former Monaco employees pull mine. Sure enough, there was one pesky corner. The replacement company sort of straightened the frame or the corner and the installation shop did a little grinding or filing to provide the proper clearance….and did not have to beat it back in. Good Luck Link to comment Share on other sites More sharing options...
