ktloah Posted October 19, 2022 Share Posted October 19, 2022 So my screen for the entry door got damaged. The frame is not damaged but the plastic inserts that keep the corners together have broken. Anybody have any suggestions as to where I can get this fixed. I have already tried a local screen door and glass repair, but no luck. Thanks Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 19, 2022 Share Posted October 19, 2022 25 minutes ago, ktloah said: So my screen for the entry door got damaged. The frame is not damaged but the plastic inserts that keep the corners together have broken. Anybody have any suggestions as to where I can get this fixed. I have already tried a local screen door and glass repair, but no luck. Thanks I’d do more searching for another local glass, patio door or even some ACE Hardware stores. but, Google may be your friend. Use this search. window screen plastic corner inserts You will get many hits. Home Depot and Amazon and many specialty houses. the OTHER option is to fix the broken ones. Now this assumes they sheared cleanly and you have two pieces. JB Clear Weld works great. Mix per instructions. Will take a few minutes to start to cure. Adjust or hold or clamp as needed to get the angle correct. Let it sit for maybe an hour and take a sharp knife or razor knife or Exacto blade and cut off any globs or excess. If the screen was never supposed to be disassembled, then use a dot or two of the JB Weld and then glue in the corner pieces. Miracle stuff Good Luck. If you find a supplier, please post info for our parts list. Thanks Link to comment Share on other sites More sharing options...
ktloah Posted October 19, 2022 Author Share Posted October 19, 2022 Thanks Tom Link to comment Share on other sites More sharing options...
Ken Thompson Posted November 5, 2022 Share Posted November 5, 2022 My Dynasty didn’t have the upper screen when I bought it. I had to make the frame and weld it together. I still have the aluminum extrusion pcs. If you are interested in building a new frame. Link to comment Share on other sites More sharing options...
ktloah Posted November 5, 2022 Author Share Posted November 5, 2022 I.would be interested, thanks Link to comment Share on other sites More sharing options...
Ken Thompson Posted November 5, 2022 Share Posted November 5, 2022 3 hours ago, ktloah said: I.would be interested, thanks I can cut the 6’ pcs. down to approx. lengths so the shipping would be cheaper as well. Link to comment Share on other sites More sharing options...
