Hancoman Posted January 24 Share Posted January 24 Good Evening. Today I went to the motor home to do a little maintenance Started the generator to charge the batteries it ran for 5 minutes and stopped, restarted run for a few seconds and stopped. I pushed it out to have a look only to see oil running out the bottom. I was able to get a pan to catch the oil. Any Ideas what kind of problem I might be facing. Thanks in advance Tom 2001 Executive Link to comment Share on other sites More sharing options...
Ivan K Posted January 24 Share Posted January 24 You really need to identify where the oil is running from. Easy access from the side opening and hopefully just a lose or double gasketed oil filter and the engine stopped due to lack of oil pressure before any damage happened. I doubt you have an oil cooler so it got to be leaking from the engine somewhere. Are you sure it isn't diesel fuel that's leaking, if clear? Link to comment Share on other sites More sharing options...
TomV48 Posted January 24 Share Posted January 24 First time I changed oil in ours, the seal/gasket/Oring on the new onan brand filter heald long enough to pass a five minute test, but dumped oil a week later tem minutes in to use. I had another filter which had the same failure, gasket would not hold it's position in place on the filter while being held horizontal up to installed. I hope your problem is that easy. But hope you don't have to clean up oil on the Elks parking lot. Link to comment Share on other sites More sharing options...
JetAburner Posted January 24 Share Posted January 24 Mine was the oil fill hose where it connects to the engine. Cut off the factory crimp clamp and replace with a worm screw type hose clamp. Dry as a bone. Link to comment Share on other sites More sharing options...
WayneC Posted January 24 Share Posted January 24 Might be an easy fix,filter may need to be snugged up, I always put a little grease on the rubber gasket and once it is hand tight I give it a 1/4 turn with my small filter pliers. Wayne 1999 Signature ceaser Link to comment Share on other sites More sharing options...
Hancoman Posted February 7 Author Share Posted February 7 Thanks for all your help. This is beyond my skill level I am going to take it in for service in a couple weeks. I will keep you posted. Link to comment Share on other sites More sharing options...
