Analyte Posted March 10, 2023 Share Posted March 10, 2023 Hello, the lower seal on my main room slide on my 2000 Dynasty got damaged as it came loose when the slide was going in or out. Is there a specific seal needed for the Monaco models, or will just a generic seal work? It seems fairly simple to change so just want to make sure I get the correct part so I don't have to do it twice. Thanks, Kerry Link to comment Share on other sites More sharing options...
96 EVO Posted March 10, 2023 Share Posted March 10, 2023 (edited) Many different types and sizes of seals are used. Measure carefully! Too short and it may not reach your slide floor. Too long, and it may come off when you extend / retract your slide. This company makes replacements for most of them....... https://www.steelerubber.com/camper-rv/slide-outs Edited March 10, 2023 by 96 EVO Link to comment Share on other sites More sharing options...
Analyte Posted March 10, 2023 Author Share Posted March 10, 2023 Thanks for the link. It looks to be just a 3in wide seal that is held in by screws. I'll take good measurements this weekend and reach out to them. Appreciate it! Link to comment Share on other sites More sharing options...
veraken Posted March 11, 2023 Share Posted March 11, 2023 I recently replaced mine. Here is where I got mine. https://www.recpro.com/rv-slide-out-seal-3-inch-wiper-seal-with-adhesive/ I reinforced it with aluminum flat bar which I got at HD https://www.homedepot.com/p/Everbilt-1-in-x-96-in-Aluminum-Flat-Bar-with-1-8-in-T-802557/204276137. Got this idea from Happycarz on IRV2. 1 Link to comment Share on other sites More sharing options...
Happycarz Posted March 13, 2023 Share Posted March 13, 2023 Kerry, Could you post a picture of your slide seal. Or even a few pictures would be nice. Monaco used so many different types of seals, it would be hard for us to offer suggestions with know what they used on your coach.. But, then again, maybe a 2000 Dynasty owner might chime in. Link to comment Share on other sites More sharing options...
96 EVO Posted March 13, 2023 Share Posted March 13, 2023 On 3/11/2023 at 5:50 AM, veraken said: I recently replaced mine. Here is where I got mine. https://www.recpro.com/rv-slide-out-seal-3-inch-wiper-seal-with-adhesive/ I reinforced it with aluminum flat bar which I got at HD https://www.homedepot.com/p/Everbilt-1-in-x-96-in-Aluminum-Flat-Bar-with-1-8-in-T-802557/204276137. Got this idea from Happycarz on IRV2. That looks pretty much like mine came from the factory on my front two slides. Link to comment Share on other sites More sharing options...
Analyte Posted March 13, 2023 Author Share Posted March 13, 2023 1 hour ago, Happycarz said: Kerry, Could you post a picture of your slide seal. Or even a few pictures would be nice. Monaco used so many different types of seals, it would be hard for us to offer suggestions with know what they used on your coach.. But, then again, maybe a 2000 Dynasty owner might chime in. Sorry, been raining all day here so I wasn't able to snap any pictures. I will when possible, but it looks the same as what veraken posted without the alum support strip. On 3/11/2023 at 5:50 AM, veraken said: I recently replaced mine. Here is where I got mine. https://www.recpro.com/rv-slide-out-seal-3-inch-wiper-seal-with-adhesive/ I reinforced it with aluminum flat bar which I got at HD https://www.homedepot.com/p/Everbilt-1-in-x-96-in-Aluminum-Flat-Bar-with-1-8-in-T-802557/204276137. Got this idea from Happycarz on IRV2. Thank you, that's the same seal as mine. Great idea on the aluminum support so appreciate you sharing that idea as well! Link to comment Share on other sites More sharing options...
Happycarz Posted March 13, 2023 Share Posted March 13, 2023 That picture he posted was of mine. It had the strip from the factory. I had to drill the rivets and replace them. Copy and paste from iRV2 post.Mine uses a 4" wide wiper seal with no bulbs. I removed the aluminum retainer, removed the old seal, and using the 5/8" attached 3M tape I stuck it in place and reattached the retainer.My seal from the factory was installed too high, causing it to curl up against the bottom of slide, and not flip back and forth as the slide moved in/out. Not a problem when new, but after 10 years it developed a set and would not seal tightly. Sitting on my couch, I could feel a draft at my ankles. I installed the new one lower so it would flip back and forth.Part # R854050 Accu-Slide It is the one in right lower of the picture, not the one with the arrow. Link to comment Share on other sites More sharing options...
Analyte Posted March 13, 2023 Author Share Posted March 13, 2023 Here is a picture of my seal. It's split in the middle of the seal, and then I have a chunk missing from the front side. Thanks again for the help! Link to comment Share on other sites More sharing options...
96 EVO Posted March 13, 2023 Share Posted March 13, 2023 Well those screws and fender washers along with the tape aren't doing too bad of a job! The aluminum strip over top would be better, but..... Link to comment Share on other sites More sharing options...
Analyte Posted March 13, 2023 Author Share Posted March 13, 2023 43 minutes ago, 96 EVO said: Well those screws and fender washers along with the tape aren't doing too bad of a job! The aluminum strip over top would be better, but..... Agreed, but it's all about making it better than when new! It definitely shows someone has worked on it before, and they chose to patch it up rather than fix correctly. Link to comment Share on other sites More sharing options...
