Paul J A Posted April 1 Share Posted April 1 Anyone know where Parts & Service is available for a Howard Precision Steering System? Link to comment Share on other sites More sharing options...
timaz996 Posted April 1 Share Posted April 1 I got rid of mine 6 years ago when I figured out my airbag valves needed to be resealed and I didn't need. Even in a nasty crosswind it runs true. Link to comment Share on other sites More sharing options...
Tom Whitlow Posted April 1 Share Posted April 1 I had a 1996 Holiday Rambler Endeavor Diesel with the Howard Steering System. Twice in 20 years (and 90,000 miles) it blew out the seals. Power steering fluid filled up the air vent bottle, overflowed, and made a nasty mess in the compartment where the system accumulator is mounted. I took it off - two big nuts on each end, two small air tubes, two hydraulic fluid tubes, and one electric terminal plug. It took less than an hour but required the help of a cheater pipe, hydraulic jack, big hammer, and cold chisel. I boxed and shipped it (UPS, about $40) to Lake Tools Hydraulic Repair in Sulfur, LA after talking to Jess Harper there. It took about 5 weeks or so for them to rebuild it ($900 + shipping back in 2014). I bolted it back on, hooked the air and fluid tubes back up, and reconnected the electric connector to the trim solenoid. I did have to readjust the cylinder to get the trim to center correctly which took about half an hour. I can attest that Lake Tools is up to the job. Expensive, but isn't everything associated with a motor home? You can call Lake Tools and talk to Jess Howard at 337-625-5737. Just FYI: I liked the system as it made driving less tiring. But, my DW (who drove just as much) didn't and never used it. Everything breaks eventually. Good luck. Link to comment Share on other sites More sharing options...
xdieselbob Posted April 1 Share Posted April 1 My 2003 Cheetah came with the Howard steering control. After researching in great lengh, how to get repairs on unit going away in 2006 I removed completely and had Safe-T-Plus unit installed. Very happy with safe-T-Plus! Link to comment Share on other sites More sharing options...
Ivylog Posted April 1 Share Posted April 1 Complicated trimming system and not sure I’d spend $1000 to fix. I remove a S-T-+ until I could trim it on the fly as it made driving noticeable tiring. Link to comment Share on other sites More sharing options...
