Les Hurdle Posted April 17, 2023 Share Posted April 17, 2023 new owner Manual says to witch to ON, wait then start Genny. Can't do that inside the coach, right? Is it ok to leave the on/off switch on the genie ON all the time? Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted April 17, 2023 Share Posted April 17, 2023 I'm pretty sure you should be able to start inside. I leave the Gen-mounted switch turned on all the time, on my Onan that switch is also the Gen. breaker. Your Cat generator may be different tho. Link to comment Share on other sites More sharing options...
96 EVO Posted April 17, 2023 Share Posted April 17, 2023 Yep, sounds like your talking about the generator breaker. Just leave it on. Link to comment Share on other sites More sharing options...
Joel & Susanna Posted April 17, 2023 Share Posted April 17, 2023 Same coach, same cat generator. You should be able to start from inside, or at the generator Link to comment Share on other sites More sharing options...
