Greg Coffey Posted April 19, 2023 Share Posted April 19, 2023 I have a 2005 Monaco Dynasty. I have been in it for the last 6 months and just returned to Canada. Took it to the RV Repair shop for aquahot warranty work. The motorhome sat for 2 days and when the shop guys went to start it,,, it would not even turn over, ,, all the dash lights worked except for the indicator on the transmission shifter. Also, the chassis batteries are 2 weeks old. Thanks to all for your responses and ideas. Much appreciated. Link to comment Share on other sites More sharing options...
timaz996 Posted April 19, 2023 Share Posted April 19, 2023 Sounds like something was left on, but your shop should know how to diagnose the problem. First check battery voltage on the chassis battery with the key on. Link to comment Share on other sites More sharing options...
BlueSteele Posted April 19, 2023 Share Posted April 19, 2023 I had a similar issue. My ECU was bad. Had it rebuilt by Transmission Instruments in Texas. They have a thorough troubleshooting procedure to follow. https://www.transmissioninstruments.com/ Best of luck. Link to comment Share on other sites More sharing options...
xdieselbob Posted April 19, 2023 Share Posted April 19, 2023 Very common problem. Shifter control also controls neutral safety switch. Look for box under shifter panel. Wiring compartment left side of driver. Box has eight screws holding cover. Remove cover and replace ten amp fuse. Light for panel should come on and neutral safety switch will now allow starter to engauge. Thousands of dollars spent for this ten amp fuse. 1 Link to comment Share on other sites More sharing options...
Greg Coffey Posted April 19, 2023 Author Share Posted April 19, 2023 Thank you very much for the replies,, I will be checking the fuse,, will let you know how it turns out. Greg Link to comment Share on other sites More sharing options...
DavidL Posted April 19, 2023 Share Posted April 19, 2023 1 hour ago, Greg Coffey said: Thank you very much for the replies,, I will be checking the fuse,, will let you know how it turns out. Greg before even doing that, check the voltage of the batteries. That's the highest probability that something was left on and the batteries are discharged. If battery are OK, then check the fuse. Link to comment Share on other sites More sharing options...
Solution Guest Ray Davis Posted April 20, 2023 Solution Share Posted April 20, 2023 Check the small wires connected to the chassis positive. There should be 2 wires & fuses, 1 for the engine & 1 for the trans. Link to comment Share on other sites More sharing options...
Greg Coffey Posted May 4, 2023 Author Share Posted May 4, 2023 It was the wiring on the battery. i had changed my chassis batteries in Az. ,, drove here and then the problem started with no start. The cables going to my batteries neg terminal, seemed tight but not tight enough and also, not cleaned properly when changed. I could have prevented the problem entirely if I had slowed down and changed my batteries properly, by cleaning the pos and neg wiring before installation. Thank you everyone for your replies. This place is a library of info,,, thanks. Regards, Greg Coffey 2005 Monaco Dynasty Diamond IV. Towing a honda Ridgeline Link to comment Share on other sites More sharing options...
