Les Hurdle Posted April 23, 2023 Share Posted April 23, 2023 Hi Folks, New to me 2004 Cheetah........ having issues with trailer wiring. In the process found rear running lights do not work. Fronts ok. Could only see fuse for headlights in manual.... rears ?? Les Link to comment Share on other sites More sharing options...
MurrayD Posted April 23, 2023 Share Posted April 23, 2023 Les, first check for power at the trailer plug by turning on the lights. If you have power on one of the pins to ground then trace the ground wire to the frame and remove and clean it thoroughly. The ground wire is almost always the failure point on trailer wiring. Likewise for the running lights. Link to comment Share on other sites More sharing options...
Les Hurdle Posted April 23, 2023 Author Share Posted April 23, 2023 Thanks, but why are the headlights working and the indicator lights? Link to comment Share on other sites More sharing options...
Steve Maurer Posted April 23, 2023 Share Posted April 23, 2023 Had same problem with tow dolly used with 2005 cheetah, problem was with spade lug connection at dolly running lights. Link to comment Share on other sites More sharing options...
