Ted Carbonaro Posted May 4, 2023 Share Posted May 4, 2023 My Power Gear Power Level system is malfunctioning. The Auto Leveling has stopped working. Which by itself would not bother my too much. But as a result the warning alarm and all lights flashing on the control panel are particularly annoying while traveling. Manual mode seems to work fine for leveling. I have check fluid and checked all electrical connections at the pump and reservoir. Has anyone had this problem and come up with the solution? Photo attached. 06 Camelot Link to comment Share on other sites More sharing options...
MrAmbassador Posted May 4, 2023 Share Posted May 4, 2023 My did it two different times. One the fluid was low. I know you checked it, but I would do it again. The oil is finicky when it comes to temperature. The second time was when the Parking Brake was not sending a signal that it has been released. I ended up having to change the air brake switch. I upgraded it to a redesigned switch that I found online. Hope this helps. Link to comment Share on other sites More sharing options...
Ted Carbonaro Posted May 4, 2023 Author Share Posted May 4, 2023 Thanks for the feedback! Link to comment Share on other sites More sharing options...
TommyL Posted May 4, 2023 Share Posted May 4, 2023 Our 08 Camelot is Valid air leveling only , pulled the ribbon connector,sprayed with electrical cleaner. All good again. Might fix yours. Link to comment Share on other sites More sharing options...
Steve P Posted May 5, 2023 Share Posted May 5, 2023 What exactly happens when you ples the On button, wait 10 seconds, and then press (and release) Auto? Link to comment Share on other sites More sharing options...
