Notn2bars Posted June 18, 2023 Author Share Posted June 18, 2023 Al and Jim, thanks for the suggestions to keep the doors and drawer closed. Al, I purchased the same fridge as you, could not get it through the door. So, put we put it in through the driver side window. Included the pic of how I covered the hole in the side of the MH. Jim, we also have a breaker for the fridge. Not going to run a separate switch. On to another project, will post that in A/C, Heating and Cooling. God Bless, Ed & Sylvia Link to comment Share on other sites More sharing options...
Guest Al redcay Posted June 18, 2023 Share Posted June 18, 2023 2 hours ago, Notn2bars said: Al and Jim, thanks for the suggestions to keep the doors and drawer closed. Al, I purchased the same fridge as you, could not get it through the door. So, put we put it in through the driver side window. Included the pic of how I covered the hole in the side of the MH. Jim, we also have a breaker for the fridge. Not going to run a separate switch. On to another project, will post that in A/C, Heating and Cooling. God Bless, Ed & Sylvia I guess you door is smaller than mine was 26 inches wide with the top hinge off , did you move your furnace. I set mine on top of my furnace. Link to comment Share on other sites More sharing options...
Notn2bars Posted June 19, 2023 Author Share Posted June 19, 2023 Al, The furnace had to be dropped all the way to the floor. With the doors of the fridge I only had 1/8 th of an inch on each side. Figured it would be safer to remove the window. Only took about 10 minutes to remove the window . God Bless, Ed & Sylvia Link to comment Share on other sites More sharing options...
