MattSw Posted June 16, 2023 Share Posted June 16, 2023 We have 2005 Windsor. The curbside kitchen slide coming in at angle. It is an electric power gear. The end nearest the front of coach is coming in first. How do I access the motor? Any help is appreciated. We are at campground and need to move soon. Thank you. Link to comment Share on other sites More sharing options...
klcdenver Posted June 16, 2023 Share Posted June 16, 2023 Lippert has YouTube videos that show you how to adjust slides. Link to comment Share on other sites More sharing options...
Solution Gary 05 AMB DST Posted June 16, 2023 Solution Share Posted June 16, 2023 A pin that holds one of the gears on the shaft may be broken and only one gear is working. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
thomasgibbens Posted June 17, 2023 Share Posted June 17, 2023 If you go to the slippery Power Gear website, there is a procedure for reprogramming the wall control to get them back in sync. You have to hold the buttons on the back side till the slide comes in and then release and press the out button while holding the buttons in again to set the out stop point. Tom Gibbens ’15 Dynasty Link to comment Share on other sites More sharing options...
MattSw Posted June 18, 2023 Author Share Posted June 18, 2023 Solved: thank you everybody It was a sheer pin on the motor. It was accessible on the curbside of the water tank bay. Not a regular door, secured by two straps underneath. Link to comment Share on other sites More sharing options...
