MJ.STIGER Posted July 3, 2023 Share Posted July 3, 2023 Information to share with all incase your run into needing to replace them. My 2005 has factory LED marker lights. And as the holy grail of PDFs on this forum. They call out to be a Dialight 200-51A. And they do not seem to be available readily for replacement. But a great 2nd is this Grand General 76320. I bought a couple different ones and this was the best fit DOT approved and looks good. You can find it on amazon if you need it right away. Grand General Amazon Link When i went to pull the only one out it was siliconed in there for good. And with the age on the plastic it broke apart. I thought it was going to be replaceable bulb. However it was LED i pulled it out and put 12v to it and only got 2 LEDs dim. The replacement is exact size. Had to dig out all the old silicone before laying the new one it. Ended up going with a nice large bead of silicone so i could lay it in and press it down. Then screwed it in same holes. Then made sure to apply a nice finger lick and seal around that whole lite. Said part is now i want to change the rest of the front markers to match. So that will be the next project. Hope this helps someone in the future with a marker lights out. 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 3, 2023 Share Posted July 3, 2023 Thanks. I’m flagging @Frank McElroy as he manages such…. Link to comment Share on other sites More sharing options...
Frank McElroy Posted July 3, 2023 Share Posted July 3, 2023 7 hours ago, MJ.STIGER said: Information to share with all incase your run into needing to replace them. My 2005 has factory LED marker lights. And as the holy grail of PDFs on this forum. They call out to be a Dialight 200-51A. And they do not seem to be available readily for replacement. But a great 2nd is this Grand General 76320. I bought a couple different ones and this was the best fit DOT approved and looks good. You can find it on amazon if you need it right away. Grand General Amazon Link When i went to pull the only one out it was siliconed in there for good. And with the age on the plastic it broke apart. I thought it was going to be replaceable bulb. However it was LED i pulled it out and put 12v to it and only got 2 LEDs dim. The replacement is exact size. Had to dig out all the old silicone before laying the new one it. Ended up going with a nice large bead of silicone so i could lay it in and press it down. Then screwed it in same holes. Then made sure to apply a nice finger lick and seal around that whole lite. Said part is now i want to change the rest of the front markers to match. So that will be the next project. Hope this helps someone in the future with a marker lights out. Thanks for this info - I'll add it to the next parts list revision. Link to comment Share on other sites More sharing options...
Mike H Posted July 3, 2023 Share Posted July 3, 2023 Glad to hear you got it worked out. 1 Link to comment Share on other sites More sharing options...
