Military RVer Posted June 21, 2020 Share Posted June 21, 2020 I do not know where this goes as I am knew. I am in need of two A/C units for my 99 Monaco. My A/C unit have both begun to fail. I am looking for a set that someone had already pulled off their RV. Hoping to find a set of Dometic 15k. Thank you. Sorry if I have placed this in the wrong location. Link to comment Share on other sites More sharing options...
K9 Exec Posted June 21, 2020 Share Posted June 21, 2020 Hello Military RVer- first of all, thank you for your service! I have an ‘02 Holiday Rambler with 2 Dometic (15k front and rear) I believe, they have heat pumps and were top of the line back in the day. I am in the process of a complete coach battery overhaul, getting rid of the FLA batts which are garbage, going Lithium, new inverter and planned on replacing the a/c for 2020’s that are supposedly “more efficient “ and draw a few less amps. Not sure where you are in the country, but I would love to see these find a new owner, since they are quiet and still work really well, rather than sit in my shop for God only knows how many years until I have a project. 🙂 I am working from an iPhone, I am not sure how/ if I can direct message- so, if you can DM me, I will shoot my contact info and we’ll go from there. Thanks, Nic Link to comment Share on other sites More sharing options...
vito.a Posted June 28, 2020 Share Posted June 28, 2020 (edited) Be careful with your A/C update. The thermostat version must match the A/C version. Or, you can install retrofit control boards. A 99 motorhome came with the old 4 button thermostat and is not compatible with any A/C units manufactured since 2002. After 2002 Dometic went to the 5 button Comfort Control thermostat. Dometic now makes the Comfort Control Center 2, a 10 button programmable thermostat for their new A/C units. You could try soldering in a charge port and recharge your old units. Many will say this is a questionable procedure but it may get you by. Or, if you watch the sales you can find new units for around $500. Edited June 28, 2020 by vito.a Link to comment Share on other sites More sharing options...
Military RVer Posted June 30, 2020 Author Share Posted June 30, 2020 On 6/28/2020 at 11:59 AM, vito.a said: Be careful with your A/C update. The thermostat version must match the A/C version. Or, you can install retrofit control boards. A 99 motorhome came with the old 4 button thermostat and is not compatible with any A/C units manufactured since 2002. After 2002 Dometic went to the 5 button Comfort Control thermostat. Dometic now makes the Comfort Control Center 2, a 10 button programmable thermostat for their new A/C units. You could try soldering in a charge port and recharge your old units. Many will say this is a questionable procedure but it may get you by. Or, if you watch the sales you can find new units for around $500. This is ok as I have the updated thermostat as well. they have also been in the elements with no cover, plastic or rv cover, on them for over 3 years. as they do not turn on or anything, I am just looking to replace. I messed up by putting it in storage and not taking care of it when I should have. Link to comment Share on other sites More sharing options...
