deputylynch Posted August 3, 2023 Share Posted August 3, 2023 (edited) Has anybody else ran into trying to remove the solar panel off of a Monaco Diplomat. I removed the four bolts that are attached to the angle brackets and the panel will not lift. When trying to look underneath, it appears that there is a junction box that is glued to the roof and I'm afraid the junction box may have been screwed down and then the panel glued to the panel box so I'm afraid to pry up on it. I want to get into that junction box wiring so I can add two additional 100 watt panels. Edited August 3, 2023 by deputylynch Picture edit Link to comment Share on other sites More sharing options...
jacwjames Posted August 3, 2023 Share Posted August 3, 2023 Mine lifted right up when I painted my roof with Topside paint. Link to comment Share on other sites More sharing options...
timaz996 Posted August 3, 2023 Share Posted August 3, 2023 I wonder what dummy thought that was a good idea? You can try lifting up and placing a two X four under it so you can reach under with a razor knife to carefully cut the adhesive as you lift it more. Link to comment Share on other sites More sharing options...
deputylynch Posted August 6, 2023 Author Share Posted August 6, 2023 This was the glob that gave me the problem! I got it pulled up and wired into the junction box with the new solar panels so all is good now. Link to comment Share on other sites More sharing options...
