Baldfuzzz Posted September 11 Share Posted September 11 Noel <baldfuzzz@gmail.com> 2:15 PM (14 minutes ago) Hi my name is Noel and I am having an airbag issues on my 2005 Monaco Camelot 40PDQ. I had airbags and air fittings with air leaks. All eight airbags were replaced as well as the fittings with air leaks. I don't have any air leaks anymore yet my rear airbags will not stay inflated after shutdown. The airbags deflate over night. Only the rear bags deflate, the front bags stay inflated. Any thoughts on what I should be looking for or what may be the possible cause of the problem? Any suggestions or recommendations will be welcome. Thanks, Noel Link to comment Share on other sites More sharing options...
timaz996 Posted September 11 Share Posted September 11 Check your rear six pack valves with either soapy water or a leak detector. That’s my first thought if your rear airbags are going down equally together. Link to comment Share on other sites More sharing options...
Baldfuzzz Posted September 11 Author Share Posted September 11 Thanks for the reply. What's a 6 pack valve and what does it look like? Do you have any idea where can I locate the 6 pack valves on my MH? Link to comment Share on other sites More sharing options...
vito.a Posted September 12 Share Posted September 12 (edited) They are groups of air solenoids (6 packs). The rear set is usually in a difficult position above the drive shaft. The coach needs to be up in the air, but you also need to be able to release the air pressure to work on them. Two methods of getting it up in the air. The first is to build some ramps out of stair stepped 2x10" boards screwed together. The second is to cut some very strong steel cylinders or square tubes cut to fit between the frame and the suspension H member. You air up the suspension all the way and then insert the spacers to keep it raised. The air tubing going into the fittings tends to leak after 10 years or so. Sometimes you can remove the tubing (air pressure must be released) then depress the lock and remove the tubing. Cut 1/4" off the end and reinsert it with some WD40 and stop the leak. Other times you need to replace the fitting. The air solenoid six packs have several orings inside. You need to remove the nut on top and disassemble the solenoids and replace the orings. Mike Canter suggests you use Dupont Viton orings. The internal oring is a -019 size, the large one on the bottom is a -028 and the small one on the bottom is a -015 (HWH suspension). It will help to have a special "pin wrench" tool and cannon plug pliers to get the valves apart. Hope this helps. Edited September 12 by vito.a Link to comment Share on other sites More sharing options...
Baldfuzzz Posted September 19 Author Share Posted September 19 Vito, thanks for your reply and sorry for late response. My mechanic advised me that it was not the 6-pack but leaks in a couple of valves sensors, air lines and several air fittings. All which got got replaced. Now the rear bags are holding air properly but the front is not. I'm not confident in my mechanic and will not not be bringing the MH to him again. Thanks again, Noel Link to comment Share on other sites More sharing options...
