charle1s Posted October 20 Share Posted October 20 Have a 2007 HR neptuneXL..the instrument cluster has become temperamental in the last year..have thrown money at it (inst. panel pulled grd and connection checked and dielectic (sp?) grease use..ok for a while..took for monthly spin yesterday with all instr. inop..after about 10 min they came back up and worked for the remainder of trip..feels like a bad ground . issue to me but looking for suggestions Link to comment Share on other sites More sharing options...
Doug and Nicki Posted October 20 Share Posted October 20 On our 2008 Dynasty, there is a ground bar on the outer firewall which can be seen when you open the generator bay. That may be a location to check. Link to comment Share on other sites More sharing options...
Luther Taylor Posted October 20 Share Posted October 20 I had a similar problem about six weeks ago, no dash at all not even intermittent. It was not a grounding problem. It was no ignition feed to field on voltage regulator, installed new independent field circuit with protection. Good luck, hope this helps. Link to comment Share on other sites More sharing options...
charle1s Posted October 20 Author Share Posted October 20 thks..I will give that a look Link to comment Share on other sites More sharing options...
charle1s Posted November 4 Author Share Posted November 4 still looking for a solution Link to comment Share on other sites More sharing options...
Tom Cherry Posted November 4 Share Posted November 4 1 hour ago, charle1s said: still looking for a solution Might help folks for you go over what you did or the specific steps you took when you “looked”…point by point or s summary often helps. Link to comment Share on other sites More sharing options...
