thomasgibbens Posted October 20 Share Posted October 20 All of my taillight lenses have frosted for whatever reason and I’m wondering if there is an easy repor to remove the frosting without damaging the lens. Tom Gibbens ’15 Dynasty Link to comment Share on other sites More sharing options...
Solution Chargerman Posted October 21 Solution Share Posted October 21 Just go to your local auto parts store and purchase a headlight lens restoration kit. They are inexpensive and it’s easy to obtain like new results Link to comment Share on other sites More sharing options...
windsorbill06 Posted October 21 Share Posted October 21 (edited) I've used this on headlights of several of our cars, bikes, quads, and rzr's. I would think it would work on tail lights as well. https://www.amazon.com/CERAKOTE-Ceramic-Headlight-Restoration-Kit/dp/B084RQKLV8/ref=sr_1_2_sspa?crid=262WJX5VUB6JF&keywords=headlight+restorer+kit&qid=1697894402&sprefix=headlight%2Caps%2C156&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 If the tail lights are frosting up because of moisture getting inside the housing, you'll likely have to replace the entire fixture. Edited October 21 by windsorbill06 Link to comment Share on other sites More sharing options...
Ron Shantos Posted October 21 Share Posted October 21 Hightly recommend. FLITZ polish till clear, then a couple coats of good wax. Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 21 Share Posted October 21 If frosting is on INSIDE, REPLACE. Get the DOT Number. Order a DOT certified replacement. It MUST have a DOT number. The cheap knockoff’s fail quickly. if there is a HAZE on the outside then the headlight kit will work. An alternative is OFF insect repellent….the one with a high DEET content. Spray a little on a terry cloth wash cloth or spray on the lens. Wipe QUICKLY. The DEET acts a plasticizer solvent and the haze will disappear. You may need to use Scratch X -2 by Mcguire’s to polish and remove streaks. Then a few coats of wax or spray with Aerospace 303. There was a great discussion recently about why purchasing a NON DOT approved cheap taillight is not cost effective. Good reading…. Link to comment Share on other sites More sharing options...
