2007 Monaco Dynasty Rear Air Tank
Go to solution Solved by LarryD,
Look on the LEFT (Driver's side).  Memory serves me right, it is there.  Has the same type of 1/4 turn valve as the front one.  Probably at eye level when you look to the left.
44 minutes ago, Brickhouse said:
I can't find the rear air tank drain. It is supposed to be in the engine compartment. Anyone have a picture of where it is?
I know our coaches are different, but mine is engine compartment mounted on the rear hitch.  Here is a pic of your manual and location.
  • 2 weeks later...
  • Solution
On my 2005 it is at and of left channel frame. Hitch mounts goes down from there. There is even a label pointing it out.
  • Thanks 1
