Greetings,  I have this code pulled up, No cruise, up or downshift on transmission.  Warning lite on constant, says vehicle speed incorrect.  I replaced Transmission output sensor with no luck.   Anyone have this problem before?
Looks like you need to check the wiring and pins for continuity.  Find the wiring schematic and check all wires go where they are supposed to.  Odds are better that a connector isn't connecting.
If you sign up on cummins quickserve for free, with your serial number, you can have it translated. This is for my ISM but likely universal. As mentioned, likely a connector contacts, the sensor is on transmission housing.
