Paul Brown Jr Posted November 8 Share Posted November 8 I own a 1996 monaco dynasty and I have a check engine light on , but it drives ok but I can not find out what is the problem can some one help? Thanks Link to comment Share on other sites More sharing options...
CRY1942 Posted November 8 Share Posted November 8 On 97 Dynasty, mechanical, Cummins, C8.3, there is only three things that will turn on the Check Engine light; Low Air Pressure, Low Oil Pressure or High Water Temperature. See attached drawing. Sorry could not figure out how to attach the drawing. 1 Link to comment Share on other sites More sharing options...
Dennis H Posted November 11 Share Posted November 11 You can do one or both of two things to find out. Least costly is to get a scan tool and hook it up. If you want the best solution, take it to a Cummins shop and have them scan all systems. They'll give you a printout of your system faults and explain what they mean. From there you can decide how to proceed. I'd get it done and fixed before you end up stuck somewhere and have to be towed.....Dennis Link to comment Share on other sites More sharing options...
dl_racing427 Posted November 12 Share Posted November 12 On 11/11/2023 at 1:24 PM, Dennis H said: You can do one or both of two things to find out. Least costly is to get a scan tool and hook it up. If you want the best solution, take it to a Cummins shop and have them scan all systems. They'll give you a printout of your system faults and explain what they mean. From there you can decide how to proceed. I'd get it done and fixed before you end up stuck somewhere and have to be towed.....Dennis Is the 1996 still a mechanical engine? No ECU to scan on those. Link to comment Share on other sites More sharing options...
Dennis H Posted November 12 Share Posted November 12 2 hours ago, dl_racing427 said: Is the 1996 still a mechanical engine? No ECU to scan on those. I never checked for a port on my 96 Dynasty. I left it to Cummins. That was before I got educated about diesel engines, of which I'm still learning.....Dennis Link to comment Share on other sites More sharing options...
Paul Brown Jr Posted November 13 Author Share Posted November 13 I have not checked the things you said but hopefully I will be able to check this week. Thanks. Link to comment Share on other sites More sharing options...
