1nolaguy Posted November 8 Share Posted November 8 The lamp in the passenger map light (goose neck 4w light attached to curbside arm rest) burned out. In checking to change I discovered the lamp housing socket was damaged (partly melted) suggesting a short. I got a new fixture (LED) to replace it but when checking the wiring I see the the voltage is 128 mili-amps so something is up. Any suggestion as to what fuse this is on and where it is located? Also, may be a bad ground? Link to comment Share on other sites More sharing options...
Tom Cherry Posted November 8 Share Posted November 8 Do you have the prints? The map lights are always called out. The Windsor/Camelot/Scepter prints are close…based on what s member, who had the prints, posted. Are they in the back of your manual? Did a search. Here is the 04….from our files. Probably close as those years had very little change and Monaco was working on upgrading the Dynasty circuits and left the rest alone… 1 Link to comment Share on other sites More sharing options...
Rocketman3 Posted November 8 Share Posted November 8 My drivers map light is on the dash lights circuit. to turn it on it is like a “dome” light in a car. Turn the dash lights brightness all the way up - then it clicks on. Your may be different. Good Luck Link to comment Share on other sites More sharing options...
1nolaguy Posted November 8 Author Share Posted November 8 Thanks, I will give that a try. We actually never use the map lights or should I say they have never worked. They just were not a high priority item. Will give this a try this weekend. Tom, thanks for the link. I did not see these when last I looked. They will really come in handy. 5 hours ago, Tom Cherry said: Do you have the prints? The map lights are always called out. The Windsor/Camelot/Scepter prints are close…based on what s member, who had the prints, posted. Are they in the back of your manual? Did a search. Here is the 04….from our files. Probably close as those years had very little change and Monaco was working on upgrading the Dynasty circuits and left the rest alone… Link to comment Share on other sites More sharing options...
Bill R Posted November 8 Share Posted November 8 8 hours ago, 1nolaguy said: The lamp in the passenger map light (goose neck 4w light attached to curbside arm rest) burned out. I replaced my map lights with these. There is even a USB plug in. https://www.amazon.com/gp/product/B0BWY9DZG5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Link to comment Share on other sites More sharing options...
1nolaguy Posted November 9 Author Share Posted November 9 Those are the same ones I bought except mine are black. Link to comment Share on other sites More sharing options...
