andersku Posted January 3 Share Posted January 3 I am replacing the keypad on my 07 Camelot 42’ PDQ and am wondering if this is a plug and play or if I will need to perform some set up procedure. Thanks in advance for the feedback Link to comment Share on other sites More sharing options...
CAT Stephen Posted January 3 Share Posted January 3 What keypad are you referring to? 1 Link to comment Share on other sites More sharing options...
andersku Posted January 3 Author Share Posted January 3 Oh geez, so embarrassed that I failed to state that I was referring to the Valid air leveling system key pad. Valid part number VTL02A008-13 Thank you Link to comment Share on other sites More sharing options...
CAT Stephen Posted January 4 Share Posted January 4 Kurt, A good place to start your journey is to contact the manufacturer directly: https://validmfg.com/contact-us/ Please post your experience and the results. 1 Link to comment Share on other sites More sharing options...
andersku Posted January 4 Author Share Posted January 4 Thank you for the feedback. That is indeed where I started and as I await their reply, I would appreciate advice from others that own the same config as my coach that have replaced their keypad. Valid regularly recommends keypad replacement due to their reported propensity for failing when getting wet. Other on this and other Monaco forums have reported that they replaced their keypads which isn’t difficult in itself, but what I had not seen was if there was any need to program or configure the keypad in a manner that is specific to my 07 Camelot 42 PDQ. Link to comment Share on other sites More sharing options...
Solution andersku Posted January 4 Author Solution Share Posted January 4 I heard back from Valid and the keypad is indeed plug and play with no set up required. 1 1 Link to comment Share on other sites More sharing options...
Paul J A Posted January 4 Share Posted January 4 3 hours ago, andersku said: I heard back from Valid and the keypad is indeed plug and play with no set up required. They are great in customer support. Link to comment Share on other sites More sharing options...
bryan browne Posted January 5 Share Posted January 5 I replaced mine last years and was plug n play, about $500. Link to comment Share on other sites More sharing options...
96 EVO Posted January 6 Share Posted January 6 On 1/4/2024 at 6:35 AM, andersku said: Thank you for the feedback. That is indeed where I started and as I await their reply, I would appreciate advice from others that own the same config as my coach that have replaced their keypad. Valid regularly recommends keypad replacement due to their reported propensity for failing when getting wet. Other on this and other Monaco forums have reported that they replaced their keypads which isn’t difficult in itself, but what I had not seen was if there was any need to program or configure the keypad in a manner that is specific to my 07 Camelot 42 PDQ. Kurt, did yours appear to have gotten wet? I think it may be their 'canned' answer when another of their keypads fail. (Yes, I've heard it myself). Link to comment Share on other sites More sharing options...
amphi_sc Posted January 7 Share Posted January 7 My Valid keypad got wet 10+ years ago from a sudden rain storm when we were out and the driver's window was cracked open. It still works for leveling, however, the "battery" light stays on and the LED's for front rear level indication may have both a red and green led on (I.e that green is apparently stuck on but the red will go out when we are level). As the keypads aren't cheap and mine functions I haven't replaced it Maybe I should while they are still available. Link to comment Share on other sites More sharing options...
96 EVO Posted January 7 Share Posted January 7 9 minutes ago, amphi_sc said: As the keypads aren't cheap and mine functions I haven't replaced it Maybe I should while they are still available. Spoke with Valid not long ago and was informed the part number has changed, but they are still making them! Mine no longer turns on without the key in ignition position, and I have to hold power button for 10sec to power off. Otherwise it's performing fine. Mine shows no evidence of ever getting wet! Link to comment Share on other sites More sharing options...
