Mroock Posted January 28 Share Posted January 28 Does anyone have info as to location of speed sensor for Aladdin system on 2005 Dynasty? Link to comment Share on other sites More sharing options...
Dr4Film Posted January 28 Share Posted January 28 @Frank McElroy will have your answer. Link to comment Share on other sites More sharing options...
Frank McElroy Posted January 28 Share Posted January 28 2 hours ago, Mroock said: Does anyone have info as to location of speed sensor for Aladdin system on 2005 Dynasty? If you are talking MPH, that data is pulled off the engine ECM databus. There is no separate Aladdin MPH speed sensor. If your issue is that the MPH on the Aladdin don't match your GPS then the issue is with the setting in the engine ECM for tire size and drive axle gear ratio. Link to comment Share on other sites More sharing options...
Mroock Posted January 28 Author Share Posted January 28 Thanks so much for information, Aladdin just shows XXX. Will that missing info stop cruise control from working? Thanks Link to comment Share on other sites More sharing options...
