bobdinsmore Posted February 22 Share Posted February 22 Has anyone repaired the BrakePro? I would if I could but I really have not been able to figure out what all the pieces are inside the unit and how they work together. Do you know of a shop that might repair these? I have two but neither works: - One applies the brakes correctly but in the process totally exhausts ALL of the air, just as if I pressed the "Push or Air Relief" button. The other properly applies the brakes but when I release the pedal it repeatedly repplies the brakes for short bursts (about three times). I've dry-lubed various points inside and checked for leaks (found none).No improvement or change in symptoms. Do these sound like circuit board problems of check valve problems? If none of the above pan out, does anyone have a working portable braking system they want to sell? Thank you for your help, Bob Link to comment Share on other sites More sharing options...
Dr4Film Posted February 22 Share Posted February 22 There is one on iRV2.com RVIBrake-3 https://www.irv2.com/rvclassifieds/showproduct.php?product=22382&title=rvi-brake-3-flat-tow-braking-system-for-toad&cat=23 Link to comment Share on other sites More sharing options...
bobdinsmore Posted February 23 Author Share Posted February 23 Thanks, Richard. I'm checking it out. Link to comment Share on other sites More sharing options...
Dr4Film Posted February 23 Share Posted February 23 I have used both the RVIBrake-2 and now the RVIBrake-3. I prefer the upgraded 3 version. You won't be disappointed. Link to comment Share on other sites More sharing options...
bobdinsmore Posted March 8 Author Share Posted March 8 Richard, Thank you for the input. I found a Brake Pro on eBay and decided to go with that one. It should arrive today. Link to comment Share on other sites More sharing options...
