joefromperry Posted March 8 Share Posted March 8 (edited) I have a white three-button remote with "somfy" on the bottom for my 2003 Signature, but have no idea what it's for. I've read maybe the Girard awning, maybe the interior window shades, or something else. It takes a 2430 button battery, but even with a new battery, it doesn't seem to control anything. Anyone have similar that can provide insight? Thanks. Edited March 8 by joefromperry Link to comment Share on other sites More sharing options...
Solution joefromperry Posted March 8 Author Solution Share Posted March 8 UPDATE: so, after messing around with it and new(er) batteries, I discovered that it controls the Girard awning. Link to comment Share on other sites More sharing options...
GNRACN Posted March 8 Share Posted March 8 Lucky you! Wish I had one. Link to comment Share on other sites More sharing options...
Bruce S Posted March 9 Share Posted March 9 This remote also controls the driver's side awning but you have to select it via the middle button. You will see 4 red LED's below the buttons and each time you depress the center button a different LED will flash, from one to four followed by all lights flashing. Your Girard is likely the first LED. If you select the second LED then the next awning will operate from the up/down buttons. If you have 3 or 4 motorized awnings they will work in a similar fashion until all LED's are flashing then they would all work together. If you press the middle button again you cycle around to the first awning in a continuous loop. The middle button also stops the awning's travel if it is in motion. Link to comment Share on other sites More sharing options...
6Wheels Posted March 10 Share Posted March 10 Somfy is a morized shade manufacturer and is one of the largest in the world. Motors (somfysystems.com) Link to comment Share on other sites More sharing options...
joefromperry Posted March 10 Author Share Posted March 10 On 3/9/2024 at 6:18 AM, Bruce S said: This remote also controls the driver's side awning but you have to select it via the middle button. You will see 4 red LED's below the buttons and each time you depress the center button a different LED will flash, from one to four followed by all lights flashing. Your Girard is likely the first LED. If you select the second LED then the next awning will operate from the up/down buttons. If you have 3 or 4 motorized awnings they will work in a similar fashion until all LED's are flashing then they would all work together. If you press the middle button again you cycle around to the first awning in a continuous loop. The middle button also stops the awning's travel if it is in motion. Well, that's interesting. My remote has just one LED below the buttons, but if I push the center button, the LED flashes once, and if I push it again it flashes twice. I have only the big awning and a door awning. But I have a three-position wall switch for the door awning, top and bottom for in and out, and middle for off. I'll have to experiment to see if/how the remote does the door. With the door switch in the middle/off position, the remote doesn't affect it. Thanks for the info. Link to comment Share on other sites More sharing options...
Capt. Tango Posted March 11 Share Posted March 11 2003 Dynasty One the best upgrades I have made was to replace the 12-volt awning motor and the roof top wind sensor and computer with a motion sensor. The original system was glitchy, rolling in when not necessary and failing to retract when needed. This system is a direct replacement and is a plug and play commonly used on residential and commercial buildings and uses the existing remote. SIMU T5 550 HZ DMI 50NM 12RPM 120V MOTOR 2004675) $600.68 (replacement) https://www.floridaautomatedshade.com/Simu-T5-550-DMI5-Radio-Hz-Override-Motor-2004675-p/2004675.htm SOMFY 1816081 Motion detector EOLIS 3D WIREFREE RTS WIND SENSOR WHITE Our Price: $218.95 https://www.floridaautomatedshade.com/Somfy-Eolis-3D-Wirefree-RTS-Wind-Sensor-1816081-p/1816081.htm Link to comment Share on other sites More sharing options...
