John C Posted March 14 Share Posted March 14 I just replaced the carpet with vinyl planks under the J-Sofa, I would like to add a seat belt, to do that I need drill two holes from the slide on passenger side down to outside and put two bolts from under the slide all the way inside and secure with nuts. The only problem is I don't know what is under the plywood, definitely don't want to break any wires or pipe. Have anyone done that? how do I find out what is under the plywood? Please advise. Thank you. Link to comment Share on other sites More sharing options...
Chargerman Posted March 14 Share Posted March 14 Go to the bays underneath to assure all wires etc. are out of the way. If there’s a bunch to avoid it would be safest to drill up from underneath Link to comment Share on other sites More sharing options...
Cubflyer Posted March 14 Share Posted March 14 I’m just wrapping up removing carpet and replacing it with LVP, on my slide-out the seat belt bolts were flat head carriage bolts that came up from the bottom, very outboard edge near the wall, where they pass thru a metal angle underneath the floor. Not just thru the wood/fiberglass floor. 1 Link to comment Share on other sites More sharing options...
saflyer Posted March 15 Share Posted March 15 (edited) 23 hours ago, Cubflyer said: I’m just wrapping up removing carpet and replacing it with LVP, on my slide-out the seat belt bolts were flat head carriage bolts that came up from the bottom, very outboard edge near the wall, where they pass thru a metal angle underneath the floor. Not just thru the wood/fiberglass floor. I’ve thought about this. Replaced my jackknife couch on the drivers side, flush floor slide out with a chair that faces forward. Would like to move one of the seatbelt bolts from the wall side of the slide to the interior side. I wondered if the bolts went through more than plywood where they are now and you answered my question, metal and plywood. Now if I move one to where the floor is just wood would it be effective for a seatbelt. Plus, slim as the seatbelt bolt head is would it interfere with slide operation in the new position. I need a solution since my wife rides in that chair. Edited March 15 by saflyer Link to comment Share on other sites More sharing options...
Chargerman Posted March 15 Share Posted March 15 (edited) I would think you would be ok if you used a large fender washer or better yet add a plate underneath in that area. More important would be how the chair is mounted. In a bad accident it would more likely be a possibility of the chair becoming detached if not securely fastened Edited March 15 by Chargerman Link to comment Share on other sites More sharing options...
saflyer Posted March 15 Share Posted March 15 6 minutes ago, Chargerman said: I would think you would be ok if you used a large fender washer or better yet add a plate underneath in that area. More important would be how the chair is mounted. In a bad accident it would more likely be a possibility of the chair becoming detached if not securely fastened Two considerations are strength of attachment and would it interfere with operation of the slide. Link to comment Share on other sites More sharing options...
bret trickett Posted March 18 Share Posted March 18 My Passenger slide out is raised (it has metal frame work in the floor base) I used a stud finder to locate them (i think there where 3 that ran long ways) Then I used stainless steel self tappers to attach 1 Link to comment Share on other sites More sharing options...
