Timmy C. Posted April 5 Share Posted April 5 I am trying to find a motor for the old style awning. Carefree says they no longer have the motor available. Has anyone been able to cross it over to another motor. It appears to be a windshield wiper motor, but I'm having no luck finding something I can retrofit. Link to comment Share on other sites More sharing options...
Wilwag Posted April 6 Share Posted April 6 Would you mind taking a pic of it? I would like to see if it’s similar to ours. We were told by one mechanic that it was a Volkswagen window motor and that they are getting very hard to find. We have a 2007 dynasty and have a picture of the awning in an older post. We haven’t had time to unassemble it ourselves to compare motors. Once we do, we will try to post our findings. Link to comment Share on other sites More sharing options...
Timmy C. Posted April 6 Author Share Posted April 6 This is a Bosch motor appears to be a wiper motor. Numbers on the motor are 058 06 01 1611 and 0 390 257 687 CHP 11v. Link to comment Share on other sites More sharing options...
Dbircky Posted April 6 Share Posted April 6 Is yours the one in the tube? If it is, it was made in Italy. Here's an option: https://www.amazon.com/Carefree-R001531-Marquee-Window-Tubular/dp/B009TNC7P0/ref=asc_df_B009TNC7P0/?tag=hyprod-20&linkCode=df0&hvadid=312094794632&hvpos=&hvnetw=g&hvrand=6459836341547814746&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9015351&hvtargid=pla-526144237331&psc=1&mcid=a95defcafe043447aa139890a9a35a84&tag=&ref=&adgrpid=60223452937&hvpone=&hvptwo=&hvadid=312094794632&hvpos=&hvnetw=g&hvrand=6459836341547814746&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9015351&hvtargid=pla-526144237331 Link to comment Share on other sites More sharing options...
Timmy C. Posted April 6 Author Share Posted April 6 No sir mine is older it is external, mounted on the end of the tube. Link to comment Share on other sites More sharing options...
Dave Shackelford Posted April 7 Share Posted April 7 On 4/5/2024 at 11:56 AM, Timmy C. said: I am trying to find a motor for the old style awning. Carefree says they no longer have the motor available. Has anyone been able to cross it over to another motor. It appears to be a windshield wiper motor, but I'm having no luck finding something I can retrofit. Take it to an alternator repair shop and have it rebuilt. I did mine and it was fast & cheap. Dave Link to comment Share on other sites More sharing options...
Solution Timmy C. Posted April 7 Author Solution Share Posted April 7 Well I have managed to drain the water and cleanup all the rusted internal parts and got the motor to run again. I realize this is probably not a long term solution, but it does work as it's designed to for now. I am going to continue the hunt for a new motor. Link to comment Share on other sites More sharing options...
Kenster Posted April 7 Share Posted April 7 I have a 2006 diplomat. What are the chances that I am changing my otd motor today. What a miserable job. You are correct, a direct replacement is not available, although Amazon is loaded with them. This is a very common motor. The difference I see is the replacement motor/ gearbox does not have the cast mounting standoffs like the original and will require shimming the bolts for the proper mounting. Assuming yours is like mine, there is some type of bastard aluminum gear/coupler attached to the original motor. This was easily removed and should reattach to the new motor. Frankly, it looks like Carefree used a hodgepodge of Parts when they were building this model. You will have to replace the three mounting bolts, and use steel spacers accordingly. These are easily available at any hardware store. The best I can tell, is this will work. It's worth a $39 try on amazon and I ordered it today and it will be here tomorrow. Don't take my word for it, do your due diligence. I'll let you know how it turns out tomorrow. Link to comment Share on other sites More sharing options...
Timmy C. Posted April 8 Author Share Posted April 8 1 hour ago, Kenster said: I have a 2006 diplomat. What are the chances that I am changing my otd motor today. What a miserable job. You are correct, a direct replacement is not available, although Amazon is loaded with them. This is a very common motor. The difference I see is the replacement motor/ gearbox does not have the cast mounting standoffs like the original and will require shimming the bolts for the proper mounting. Assuming yours is like mine, there is some type of bastard aluminum gear/coupler attached to the original motor. This was easily removed and should reattach to the new motor. Frankly, it looks like Carefree used a hodgepodge of Parts when they were building this model. You will have to replace the three mounting bolts, and use steel spacers accordingly. These are easily available at any hardware store. The best I can tell, is this will work. It's worth a $39 try on amazon and I ordered it today and it will be here tomorrow. Don't take my word for it, do your due diligence. I'll let you know how it turns out tomorrow. Sounds exactly like the same setup as mine. Hope it works out. As bad as mine looked internally I know it won't last. I did try and make it water tight when I reinstalled it. Link to comment Share on other sites More sharing options...
Kenster Posted April 8 Share Posted April 8 5 minutes ago, Timmy C. said: Sounds exactly like the same setup as mine. Hope it works out. As bad as mine looked internally I know it won't last. I did try and make it water tight when I reinstalled it. I should have mine tomorrow. I'll let you know how it goes and what shims and bolts are needed. Link to comment Share on other sites More sharing options...
Kenster Posted April 8 Share Posted April 8 The motor I received from Amazon is not the correct motor. I'll research a little more and keep you posted. Link to comment Share on other sites More sharing options...
Kenster Posted April 8 Share Posted April 8 The new motor does not fit. I disassembled my original motor; which appears to have been salvaged from the Titanic. Time to go to plan B; not the pill. Fyi, I have no plan b. Link to comment Share on other sites More sharing options...
Timmy C. Posted April 8 Author Share Posted April 8 I was afraid the new motor would not work, I was back and forth on it myself. I do believe yours looks a little worse than mine did, and it was still holding water. Link to comment Share on other sites More sharing options...
Kenster Posted April 9 Share Posted April 9 Can you read the entire Bosch number on your housing? The only part of mine I can read is Bosch 058-05-?????? I have found a replacement motor but the problem is the splined shaft in the original motor. Did yours have a bastardized aluminum spline gear on the motor that was TIG welded to a aluminum half inch square coupler? Or am I just special; and I don't mean riding the short yellow bus. Link to comment Share on other sites More sharing options...
Timmy C. Posted April 9 Author Share Posted April 9 Yes the numbers on the motor are Bosch 058 06 01 1611 and 390 251 687 CHP 11v. I also have the aluminum gear welded to a square coupler. Hope this helps. I have not seen a wiper motor that has a straight splined shaft or with a gear on it. the window regulator motors seem to be more likely to have a gear on them. Link to comment Share on other sites More sharing options...
Kenster Posted April 9 Share Posted April 9 Tim, can you call me. 702.524.6577 Ken Don't buy an awning yet. I may be on to something. Link to comment Share on other sites More sharing options...
Kenster Posted April 21 Share Posted April 21 I found the retrofitable motor which is slightly more powerful and a 10 mm D motor shaft/half inch square awning shaft adapter coupler online. Drilled two additional holes in what I call the P mounting plate and the shortened the adapter coupler by half of an inch. Far better than that POS welded aluminum do half inch adapter the manufacturer originally used. I have created a form that profiles the new motor as it is slightly larger than the original motor preventing me from using the original motor cover. All but one of my fiberglassing supplies arrived today preventing me from starting to create the new cover. Link to comment Share on other sites More sharing options...
