Jlalpaugh Posted April 10 Share Posted April 10 My steps are stuck open. The 25 amp fuse had blown, when replaced it blows instantly. I have not had any issue with the steps prior. Link to comment Share on other sites More sharing options...
Chargerman Posted April 10 Share Posted April 10 Sounds like you have a dead short somewhere. I would dig in under the step to look for a wire that has been compromised Link to comment Share on other sites More sharing options...
Rick Rutel Posted April 11 Share Posted April 11 Check the wires where they feed into the step motor. One may have grounded out. A dead short seems like the culprit. Link to comment Share on other sites More sharing options...
cbr046 Posted April 11 Share Posted April 11 Disconnect the connector underneath at the steps and see if the fuse still blows. That will eliminate a lot of possibilities . . . .or identify the problem is upstream. - bob 1 Link to comment Share on other sites More sharing options...
Ron Doty Posted April 12 Share Posted April 12 I agree, a bare wire, a loose plug-in connector. A cautionary note: I just replaced the controller, at an RV Repairman’s diagnoses, HOWEVER, it blew the fuse again after the new controller was installed. A burnt spot on the plug in connector to the controller on the coach side was the culprit. Guess what, no refund on the newly installed Controller that I did not need, ALSO, no break on RV Repairman’s Fees, he said, “Would have never found the bad connector without replacing the Controller”. I told him “ Give me the old controller there is apparently nothing wrong with it”. Trail and error method, as opposed to testing connections to assure the Controller was getting volts it needed. Link to comment Share on other sites More sharing options...
