Monarch03SE Posted June 16 Share Posted June 16 I own a 2003 Monaco Monarch Se 34 Pbd.I drove the coach about 10 miles to park at a friends.I put the Rv in park on the swell and my friend said pull it along the fence.I attempted to start the Rv which has a new starter,new batteries even changed out my relays to make sure I covered the basis.What I did find was a knock sensor that was pretty cooked along with the wiring harness would this be enough for the coach not starting.My next thought is it the Electonic Module control Switch or the Transmission Module Control Switch.I am frustrated because my obd 2 scanner isn’t giving me much information and the coach has 3/4 tank of fuel or could it be something else that’s hindering the coach from starting.Appreciate any advice and no I have not replaced the knock sensors yet. Link to comment Share on other sites More sharing options...
klcdenver Posted June 16 Share Posted June 16 Your attachments/pictures are blank. Maybe try again. Link to comment Share on other sites More sharing options...
jacwjames Posted June 16 Share Posted June 16 (edited) No start could be as simple as parking brake not on or not in neutral. Suggest starting with the basics and checking the simple stuff. Do you have power when you turn the key, are lights on the dash displayed? Edited June 16 by jacwjames Link to comment Share on other sites More sharing options...
Monarch03SE Posted June 16 Author Share Posted June 16 Yes I’m getting power when I turn the key the motor just won’t turn over? Link to comment Share on other sites More sharing options...
cbr046 Posted June 17 Share Posted June 17 Will it start if the slide(s) are out? Maybe a safety switch gone rogue . . . This is a gasser, right? Possible fuel pump issue? - bob (grasping at straws) Link to comment Share on other sites More sharing options...
