thancoc@bellsouth.net Posted November 30, 2020 Share Posted November 30, 2020 Had a buddy follow me into our site and he made me aware that my brake lights were out. Up on checking them out, my center brake light works, but neither of my side brake lights work. I tried replacing the 7866 fuse in the fuse center on drive side compartment, but after thinking it through: thought if the center is working something else is going on. Thought appreciated! Link to comment Share on other sites More sharing options...
PeterSchweizer Posted November 30, 2020 Share Posted November 30, 2020 Follow the center tail light wiring on my 04 Cayman it goes to the Left taillight the wiring issue its most likely a connector around there check grounds at tail lights too. Link to comment Share on other sites More sharing options...
thancoc@bellsouth.net Posted November 30, 2020 Author Share Posted November 30, 2020 6 minutes ago, PeterSchweizer said: Follow the center tail light wiring on my 04 Cayman it goes to the Left taillight the wiring issue its most likely a connector around there check grounds at tail lights too. Thanks Peter will take a look in the am and advise!! Link to comment Share on other sites More sharing options...
Gary_Curtis Posted December 1, 2020 Share Posted December 1, 2020 I have a 2007 Beaver on the Monaco Roadmaster Chassis and it uses a separate relay to drive the brake lights (Rear Run Box, board 2-K4). This relay may be bad or there is a 15 amp fuse (RRB-2-F2) that drives it that might be bad in the RRB. The center (Cyclops) brake light is driven by the brake light signal (TS1- Brake Switch Terminal) in the front run box. (Dwg#38070227) Turn Signals.pdf Link to comment Share on other sites More sharing options...
Jim Andrews Posted December 1, 2020 Share Posted December 1, 2020 Try checking the switch behind the brake peddle 1st. See if you have power to the switch. Make sure power goes thru the switch. If you don't, ohm out the switch. If you have power to the through the switch. See if you have power to the bulb, if you do, you probably have a ground problem. Place a temporary wire from the bulb to the ground. If no power to the switch or bulb, it's probably a cut wire or relay. Don't forget to use the chassis for the ground, not ground wire. Hope this helps. Link to comment Share on other sites More sharing options...
nocreek141 Posted December 1, 2020 Share Posted December 1, 2020 Well I lost one brake lite and it turned out to be a burned out taillight circuit board. I had checked every thing that I could think of, no solution. Removed good taillight assy. and plugged into the original non- functional circuit. Lights worked. The taillight assy. on my coach consists of two parts the lens/reflector assy. and the taillight circuit board that is attached by screws to the front lens assy. The bulbs are socketed in this and the wire plug attaches to it also. Got a new one on Amazon for $15, made by Dorman. Does seem weird that both are gone but I may have been driving around without a taillight for some time. Just happened my brother noticed when he followed me. Link to comment Share on other sites More sharing options...
