ronwtg Posted December 10, 2020 Share Posted December 10, 2020 The drop down front TV will not work. Two years ago I had a bad blowout and when I got the coach back a year later the TV would not come down. I have had it to several RV repair shops. They found several things that it could be. 1. The circuit board may be bad. For $450 I could send it off to see if it could be repaired. They no longer make the board and if it can’t be repaired I’m out the money. 2. the motor is bad. I have not tested it but I was told this. I searched for the motor and it is not available. For now I have disconnected the lift and made brackets to hold the TV up. I have replaced the old TV with a much lighter digital one. Since RV repair seems only to have part changers I have decided to revamp the lift system myself. I was wondering if anyone had done this to their lifts. It seems the maker has gotten out of this type of lifts so a total refabrication is in order. Before I try to reinvent the wheel I thought I’d ask. Ron Stevenson 2004 Signature Castle Link to comment Share on other sites More sharing options...
Bruce B Posted December 10, 2020 Share Posted December 10, 2020 Ron, When replacing the original television in my drop-down unit I had an issue with it not going up or down, luckily, it was stuck in the down position. I found that the plug for the motor had worked loose. Prior to that I checked the wall switch and fuses and found them to be good. Elsewhere on this Forum there is a discussion about the TV lift and there are new replacements by current manufacturers for the lift if it has stopped working. They are quite robust so I would be surprised if it died. I was in Indio, CA at the time and had a very experienced Tech helping me, I hope you sort it out. Look at the Monaco Parts List in the downloads section and on page 179 the manufacturers are listed for the original lift and new lifts. Beautiful coach! I have the same paint scheme. Cheers Link to comment Share on other sites More sharing options...
Bo Neece Posted December 10, 2020 Share Posted December 10, 2020 Check these out. There may be one that works for your application. MOTORHOME | MORryde Link to comment Share on other sites More sharing options...
Vince Toscano Posted December 10, 2020 Share Posted December 10, 2020 Hi Ron, Do you who is the manufacture of the drop down? One item to check is if the motor is 120 vac or is it 12 dc? If the motor is ac it may be the capacitor? Not sure if your has limit switches? Do you know where the control box is? Do you any pictures of the unit? let me know. Vince Link to comment Share on other sites More sharing options...
ronwtg Posted December 10, 2020 Author Share Posted December 10, 2020 2 hours ago, Bruce B said: Ron, When replacing the original television in my drop-down unit I had an issue with it not going up or down, luckily, it was stuck in the down position. I found that the plug for the motor had worked loose. Prior to that I checked the wall switch and fuses and found them to be good. Elsewhere on this Forum there is a discussion about the TV lift and there are new replacements by current manufacturers for the lift if it has stopped working. They are quite robust so I would be surprised if it died. I was in Indio, CA at the time and had a very experienced Tech helping me, I hope you sort it out. Look at the Monaco Parts List in the downloads section and on page 179 the manufacturers are listed for the original lift and new lifts. Beautiful coach! I have the same paint scheme. Cheers Thanks, yours looks exactly like mine. We have been through everything, or I should say the tech has. I’m about to get into it myself. Surely they checked the plug but you never know. Ron 14 minutes ago, Vince Toscano said: Hi Ron, Do you who is the manufacture of the drop down? One item to check is if the motor is 120 vac or is it 12 dc? If the motor is ac it may be the capacitor? Not sure if your has limit switches? Do you know where the control box is? Do you any pictures of the unit? let me know. Vince Vince, I think it is made by Tri Metals Fabrication. This unit folds down toward the front of the coach. The switch is 12 volt but the motor is 120. If your standing look towards the front of the coach the motor, actuator and circuit boards are all on the left side above the drivers seat. I think it does have limit switches but it’s been almost a year since I’ve had it apart. I’m not at the coach but I’ll take some pictures tomorrow. I will have to dismantle it. Right now it is unhooked from the lift. I am the lift we fabricated brackets to hold it in the closed position for travel. It’s heavy. Most of the weight is the mount. I have a 43” Samsung flat screen on it that only is about 40lbs or less. Thanks I’ll get some pictures. Ron Link to comment Share on other sites More sharing options...
Vince Toscano Posted December 10, 2020 Share Posted December 10, 2020 HI Ron, It sounds very similar to the one I have in my 2003 Beaver. this is the motor, control box and capacitor. the motor can be checked with out the control box. let me know if this equipment looks the same. Sometimes the capacitor dries up and shorts internally. this effect will be the motor hums but does not move. I should ask if you are hearing any thing when you go to move your tv drop down? Vince Hi Ron, If you want to talk it may be much better than emailing. Let me know. Vince 814.327.0245 1 Link to comment Share on other sites More sharing options...
ronwtg Posted December 11, 2020 Author Share Posted December 11, 2020 Vince, Here are some pictures I took today. They do look a lot alike. I didn’t find the capacitor. The motor and the actuator are behind the limiting switches. I’ll look at it tomorrow and give you a call. Thanks, Ron Link to comment Share on other sites More sharing options...
Blacknight Posted December 11, 2020 Share Posted December 11, 2020 Ron-excuse me-completely off subject-who/where do i look for the clear protect "bra" on the front of your beautiful coach? thanks Link to comment Share on other sites More sharing options...
ronwtg Posted December 11, 2020 Author Share Posted December 11, 2020 3 hours ago, Blacknight said: Ron-excuse me-completely off subject-who/where do i look for the clear protect "bra" on the front of your beautiful coach? thanks It came with the coach but it was made by Summit Products in Iowa. I talked with them last year and they had stopped producing them. 3 hours ago, Blacknight said: Ron-excuse me-completely off subject-who/where do i look for the clear protect "bra" on the front of your beautiful coach? thanks It came with the coach when I got it. 3 hours ago, Blacknight said: Ron-excuse me-completely off subject-who/where do i look for the clear protect "bra" on the front of your beautiful coach? thanks Vince, here are some pictures I took today. They do look a lot alike Link to comment Share on other sites More sharing options...
directorsusa Posted December 11, 2020 Share Posted December 11, 2020 Mine did the same thing. I have yet to fix but found this a while back on youtube. Jarred A 2004 HR Navigator 1 Link to comment Share on other sites More sharing options...
Rob M cKeown Posted December 12, 2020 Share Posted December 12, 2020 I have an 03 Sig and had a problem after a bad electrical issue at a campground pedestal that caused the TV drop down mechanism to stop working. There is a limit switch on the right hand side that was forced out of adjustment and when I reset it it worked fine. It is very sensitive on adjustment and does not take much movement to make a change. Link to comment Share on other sites More sharing options...
directorsusa Posted December 12, 2020 Share Posted December 12, 2020 Anyway you could possibly post a picture of this device/location for future reference? Jarred A 04 HR Nav Link to comment Share on other sites More sharing options...
Rob M cKeown Posted December 12, 2020 Share Posted December 12, 2020 I will be at my coach on Monday. I will take a couple of photos and post. When the TV is down there is a cover on the left side (looking out the front window from inside) you have to remove to get at the 2 limit switches. Link to comment Share on other sites More sharing options...
ronwtg Posted December 14, 2020 Author Share Posted December 14, 2020 On 12/10/2020 at 2:18 PM, Vince Toscano said: Hi Ron, Do you who is the manufacture of the drop down? One item to check is if the motor is 120 vac or is it 12 dc? If the motor is ac it may be the capacitor? Not sure if your has limit switches? Do you know where the control box is? Do you any pictures of the unit? let me know. Vince On 12/10/2020 at 2:32 PM, ronwtg@sbcglobal.net said: Thanks, yours looks exactly like mine. We have been through everything, or I should say the tech has. I’m about to get into it myself. Surely they checked the plug but you never know. Ron On 12/10/2020 at 2:18 PM, Vince Toscano said: Hi Ron, Do you who is the manufacture of the drop down? One item to check is if the motor is 120 vac or is it 12 dc? If the motor is ac it may be the capacitor? Not sure if your has limit switches? Do you know where the control box is? Do you any pictures of the unit? let me know. Vince On 12/10/2020 at 2:32 PM, ronwtg@sbcglobal.net said: Thanks, yours looks exactly like mine. We have been through everything, or I should say the tech has. I’m about to get into it myself. Surely they checked the plug but you never know. Ron On 12/11/2020 at 5:29 AM, directorsusa said: Mine did the same thing. I have yet to fix but found this a while back on youtube. Jarred A 2004 HR Navigator This looks a lot like mine. I had to stop working on it due to an emergency. When I get back at it I’ll let y’all know what I find. Ron Link to comment Share on other sites More sharing options...
