thomasgibbens Posted January 4, 2021 Share Posted January 4, 2021 I need to splice my fresh water hose due to a break in it. I tried a barbed brass connector with hose clamps but it still drips and it is very bulky on the take up reel. I t looks like quite a job to get the reel out so I prefer the splice. Any suggestions? Tom Gibbens ’15 Dynasty Link to comment Share on other sites More sharing options...
bklaes Posted January 4, 2021 Share Posted January 4, 2021 Following. Link to comment Share on other sites More sharing options...
philcarrell Posted January 4, 2021 Share Posted January 4, 2021 Tom if you pull the hose all of the way out can't you replace it without removing reel? If not go find a plastic barbed fitting and use the pex type fitting to clamp it. 2 Link to comment Share on other sites More sharing options...
Steven P Posted January 5, 2021 Share Posted January 5, 2021 When I replaced mine it was a chore. Had to remove the screws and lower the panel and still had trouble. I ended up cutting the hole larger for better access. Mine was bad at the reel so splicing was not an option for me. Personally I've had good luck w hose parts at our Ace store. Maybe a plastic splice? Link to comment Share on other sites More sharing options...
thomasgibbens Posted January 5, 2021 Author Share Posted January 5, 2021 My hose goes through a slot in the reel to attach to it. There’s a heavy duty rubber shroud on the hose there so I would have to take the reel out to get to it. Link to comment Share on other sites More sharing options...
Mike H Posted January 5, 2021 Share Posted January 5, 2021 If you have a Glendinning hose reel there aren't many easy options. I had about 15 ft of my hose that had aged and gotten brittle from exposure. I called them to see about replacing the hose and they will only sell you a complete spool assembly ($132 as of today). At the time I didn't want to deal with the hassle of tearing out the old one so I just cut the bad section off and re-terminated it with the original end fitting they had on it. It appears they have some sort of proprietary hose connection inside of the spool, or it takes maybe a special tool to terminate it there. Splicing in a new hose at that point, or anywhere in between, makes for a very cumbersome ordeal winding the hose back up. I have never had a problem of not having enough hose to reach and campground connection but I do carry extra hose with me, just in case. Link to comment Share on other sites More sharing options...
