Margie 0 Posted February 16 Share Posted February 16 We have a 2007 Camelot 40ft and cannot get the auto leveling to work. We have the Valid air leveling system. Parked at campground and the coach is staying in ride height. Looking for leads to check what is causing our problem. Thanks Link to post Share on other sites
Hypoxia 20 Posted February 16 Share Posted February 16 17 minutes ago, Margie said: We have a 2007 Camelot 40ft and cannot get the auto leveling to work. We have the Valid air leveling system. Parked at campground and the coach is staying in ride height. Looking for leads to check what is causing our problem. Thanks Here's the service manual. Service Manual VTL05M001-SM-1.pdf 1 Link to post Share on other sites
Paul A. 29 Posted February 16 Share Posted February 16 Hold the POWER button down a bit. It may re-boot. Link to post Share on other sites
96 EVO 26 Posted February 18 Share Posted February 18 Will it go into manual mode? If so, it could be your parking brake switch. Also, the Valid control panels fail frequently. Link to post Share on other sites
willbo777 7 Posted February 19 Share Posted February 19 Give them a call, their customer service has always been great. Link to post Share on other sites
Margie 0 Posted February 20 Author Share Posted February 20 On 2/16/2021 at 12:32 PM, Paul A. said: Hold the POWER button down a bit. It may re-boot. Could not get it to reboot. We also removed the panel and checked the connections which look good. Checked all the fuses and found nothing. On 2/18/2021 at 6:03 PM, 96 EVO said: Will it go into manual mode? If so, it could be your parking brake switch. Also, the Valid control panels fail frequently. Does not go into manual On 2/16/2021 at 9:46 AM, Hypoxia said: Here's the service manual. Service Manual VTL05M001-SM-1.pdf 3.78 MB · 13 downloads Thank you for the manual Link to post Share on other sites
