Scott 61 Posted April 15, 2021 Share Posted April 15, 2021 I am getting ready to clean the rear Radiator on my motorhome Does the Back Grill come off the motor home to get better access to the radiator Mixing up a solution of simple green HD Pro and water to spray on the radiator I have an 08 Holiday Rambler Endeavor thank you all Link to comment Share on other sites More sharing options...
Gary M Posted April 15, 2021 Share Posted April 15, 2021 If yours is similar to my coach, open the two side doors next to grill. Then pull grill out. The doors help hold it in. 1 Link to comment Share on other sites More sharing options...
John Haggard Posted April 15, 2021 Share Posted April 15, 2021 I use simple green also. Be certain to rince very well For quite some time. The first rence I add a drop of Dawn soap. Then pure water after that. Lots of water. Link to comment Share on other sites More sharing options...
Gary M Posted April 15, 2021 Share Posted April 15, 2021 20 minutes ago, John Haggard said: I use simple green also. Be certain to rince very well For quite some time. The first rence I add a drop of Dawn soap. Then pure water after that. Lots of water. Have you used the simple green that is safe for aluminum. Link to comment Share on other sites More sharing options...
John Haggard Posted April 15, 2021 Share Posted April 15, 2021 19 minutes ago, Gary M said: Have you used the simple green that is safe for aluminum. Yes For aluminum air plains, airstreams We order the simple green on line 1 Link to comment Share on other sites More sharing options...
Scott 61 Posted April 15, 2021 Author Share Posted April 15, 2021 I am going to use Simple Green Pro HD it is safe for aluminum? 1 Link to comment Share on other sites More sharing options...
John Haggard Posted April 15, 2021 Share Posted April 15, 2021 12 minutes ago, Scott 61 said: I am going to use Simple Green Pro HD it is safe for aluminum? That's all I use on my boat also. Lots of ionized aluminum that I don't want discolored. Link to comment Share on other sites More sharing options...
Dennis H Posted April 16, 2021 Share Posted April 16, 2021 The PURPLE stuff, NOT the GREEN STUFF. The Simple Green, green stuff will damage the radiator. It's not made for aluminum. ALWAYS read the labels....Dennis Link to comment Share on other sites More sharing options...
John Haggard Posted April 16, 2021 Share Posted April 16, 2021 ( For aircraft ) ( Non corrosive ) ( Non hazard ) allowed for use in Harbors also Yes, follow directions, dilute as recommended, as I stated above. I do rince heavily. First time rince with a light dawn suction. ( D617487P ) Link to comment Share on other sites More sharing options...
Paul A. Posted April 16, 2021 Share Posted April 16, 2021 21 hours ago, John Haggard said: Yes For aluminum air plains, airstreams We order the simple green on line Some evening After you clean the radiator, put a light in the engine compartment shining on the engine side of the radiator. You will see the spots that may need additional attention. Link to comment Share on other sites More sharing options...
John Haggard Posted April 16, 2021 Share Posted April 16, 2021 2 minutes ago, Paul A. said: Some evening After you clean the radiator, put a light in the engine compartment shining on the engine side of the radiator. You will see the spots that may need additional attention. I Don't know Paul ? I always wash , rince the engine and engine bay down with a solution of dawn or such. Then rince , then blow dry with a leafe blower. And air Chuck. As a part of the radiator rincing process. Then we wipe most everything down that we can reach. I think cleaning the engine and engine compartment is a part of the radiator cleaning process. I do have the original radiator that Monaco installed in 99. Every now and then I visit with source engineering and they think the cooling unit will last another 20 years the way we maintain it. We do use the same process with the 14 farm over the road MACK tractors that we have. Regardless of the product that you choose to use 1. Follow the directions 2. Wash till clean. 3. Immediately rince First rince with a mild detergent Then rince, rince, rince with lots of fresh water. Immediately blow dry as good as possible Then with an air Chuck. Then hand dry as much as possible. I hate residue, calcium or soap residue on any surfaces.inside or outside. Paint, fiberglass or any metal. Link to comment Share on other sites More sharing options...
