MHRookie Posted May 14, 2021 Share Posted May 14, 2021 Anyone use the Expello electric air tank spot valves to prevent moisture? My coach has ZERO valves on the tanks to bled condensates air. expello or stick with manual dump valves? Link to comment Share on other sites More sharing options...
Ivylog Posted May 14, 2021 Share Posted May 14, 2021 (edited) Have you looked under the front cap, passenger side for small manual valves? The makeup/ tow air quick connect has a valve too that drains one of the tanks. Edited May 15, 2021 by Ivylog Link to comment Share on other sites More sharing options...
MHRookie Posted May 15, 2021 Author Share Posted May 15, 2021 Ivylog, Front passenger under headlight has a drain but nothing for rear of coach. Airline connection is above propane tank drivers side. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 15, 2021 Share Posted May 15, 2021 I have gotten under the coach on rare occasions and each time which is NOT often there hasn't been ANY moisture in the tanks when I open the drain valve. I guess I have an exceptionally efficient Air Dyer and maintenance schedule. Link to comment Share on other sites More sharing options...
