powersltc Posted May 30, 2021 Share Posted May 30, 2021 Ron P., 2004 Monaco Executive QUESTION? Has anyone ever changed the heater hose from the engine to the Aqua-Hot? I need to replace the hose and any ideas/suggestions would be Appreciated. Link to comment Share on other sites More sharing options...
vito.a Posted May 30, 2021 Share Posted May 30, 2021 One of the IRV2 members (Mike) replaced all of his heater and Aqua Hot hoses with high qualty silicone hose and stainless clamps. You'll have to read through the thread as there are lots of pages. https://www.irv2.com/forums/showthread.php?t=237276 Link to comment Share on other sites More sharing options...
vito.a Posted May 30, 2021 Share Posted May 30, 2021 Mike said some of the hose runs were a two person job so his son helped him. He installed a cutoff valve to isolate the engine in case of hose failure. Mike Z also has a You Tube channel with some great motor home repair videos. Link to comment Share on other sites More sharing options...
Hypoxia Posted May 31, 2021 Share Posted May 31, 2021 My 2007 may be different, I did it myself and didn't think it was difficult. You can either put an inline hose connector on and pull it through or if it is zip tied/clamped, which mine was I just fished it through. I used 5/8" red heater hose, the High Temperature hose. 1 Link to comment Share on other sites More sharing options...
trailmug Posted June 1, 2021 Share Posted June 1, 2021 Any fancy considerations for burping the AH engine coolant loop? I thought I remembered a forum member having difficulty with engine heat transfer after having the hoses replaced. Link to comment Share on other sites More sharing options...
