TOBYLB4 Posted June 2, 2021 Share Posted June 2, 2021 Leak appears to be coming from the head above the ECM. Anyone else run into this? Hoping it's the head gasket. Any help appreciated. Link to comment Share on other sites More sharing options...
vito.a Posted June 2, 2021 Share Posted June 2, 2021 Oil leak? Maybe the valve cover gasket? I'd be hoping it's not the head gasket. That would be a major repair. Link to comment Share on other sites More sharing options...
Dr4Film Posted June 2, 2021 Share Posted June 2, 2021 What are you leaking? With more information you would get more possibilities. Link to comment Share on other sites More sharing options...
TOBYLB4 Posted June 2, 2021 Author Share Posted June 2, 2021 2 hours ago, Dr4Film said: What are you leaking? With more information you would get more possibilities. Oil leak. I put that in the tags. Link to comment Share on other sites More sharing options...
Dr4Film Posted June 2, 2021 Share Posted June 2, 2021 (edited) 1 hour ago, TOBYLB4 said: Oil leak. I put that in the tags. OK Oil leak. What tags are you referring to as your post mentions nothing about an oil leak that I can see. What am I missing? As Vito.a stated, valve cover gasket would be what I would look for first. Then once that has been eliminated start looking elsewhere. 4 hours ago, TOBYLB4 said: Leak appears to be coming from the head above the ECM. Anyone else run into this? Hoping it's the head gasket. Any help appreciated. Edited June 2, 2021 by Dr4Film Link to comment Share on other sites More sharing options...
TOBYLB4 Posted June 3, 2021 Author Share Posted June 3, 2021 If you look under my heading "07 Dynasty ISL 400 you will see oil leak. And no it's not the valve cover. That's what you're missing. Link to comment Share on other sites More sharing options...
Dr4Film Posted June 3, 2021 Share Posted June 3, 2021 28 minutes ago, TOBYLB4 said: If you look under my heading "07 Dynasty ISL 400 you will see oil leak. And no it's not the valve cover. That's what you're missing. Gary, thanks for pointing that out. On my screen that "Tag" is so light and small that I had to get closer to the laptop screen just to read it. That's how I missed it completely. If it was in a bigger font and in dark bold letters I would have seen it for sure. Link to comment Share on other sites More sharing options...
