Mike Wahl Posted June 17, 2021 Share Posted June 17, 2021 I have a 2001 Monaco Signature. I has a updated Remco 55Aquajet-ARV pump with a Intellitec 10 amp latching controller.. The system pumps water with good pressure however the have the following problems. 1) The pump runs continuously 2) When you start the pump, none of the lights on the pump motor button aluminate. I have check for leaks and cant find any that would cause the pump to run all of the time. What else could cause this to happen? Link to comment Share on other sites More sharing options...
Ivylog Posted June 17, 2021 Share Posted June 17, 2021 Close the city water fill valve. Link to comment Share on other sites More sharing options...
Dr4Film Posted June 17, 2021 Share Posted June 17, 2021 It needs to build up pressure for the pressure switch to activate and shut it off. It sounds like the pump is circulating water from the fresh water supply tank back to the same tank. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted June 17, 2021 Share Posted June 17, 2021 Check for air in your water lines. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
waterskier_1 Posted June 17, 2021 Share Posted June 17, 2021 2 hours ago, Mike Wahl said: I have a 2001 Monaco Signature. I has a updated Remco 55Aquajet-ARV pump with a Intellitec 10 amp latching controller.. The system pumps water with good pressure however the have the following problems. 1) The pump runs continuously 2) When you start the pump, none of the lights on the pump motor button aluminate. I have check for leaks and cant find any that would cause the pump to run all of the time. What else could cause this to happen? 1) Besides the suggestions above, you could have a piece of dirt or something blocking the internal check valve, such that it never builds pressure, and simply backflows to the tank. 2) What do you mean by "lights on the pump motor button"? Are you referring to the lights on the switches throughout the coach to turn on and off the water pump? Link to comment Share on other sites More sharing options...
Ivylog Posted June 17, 2021 Share Posted June 17, 2021 2 hours ago, Chuck B said: Check for air in your water lines. Chuck B 2004 Windsor The accumulator is essentially air in the water lines… keeps pump from coming on as often. Link to comment Share on other sites More sharing options...
Mike Wahl Posted June 22, 2021 Author Share Posted June 22, 2021 I figured out the issue. Thanks for the sending me in the right direction. When I checked the city water fill valve it was closed, however with the hose disconnected and the pump running the pump pushed the water out of the city water fill connection and onto the ground. I removed the backflow valve and I found that it didn't have any internal parts in it. When I worked on it last week I had the hose still hooked up so it was pushing the pressure down the hose and I'm guessing opening the backflow valve on the hose connection at the house. I wasn't looking for a leak there. I went to the local pumping supply house and picked up a new 1/2 backflow valve and installed. This for the help with this one. Still working on the switch lights. On 6/17/2021 at 3:52 PM, waterskier_1 said: 2) What do you mean by "lights on the pump motor button"? Are you referring to the lights on the switches throughout the coach to turn on and off the water pump? Waterskier_1, yes I'm referring to the lights on the switches throughout the coach. None of them come on when the pump is running. Link to comment Share on other sites More sharing options...
