Joel & Susanna Posted June 25, 2021 Share Posted June 25, 2021 Ok folks, I wonder if anyone had this issue with your rear turn signals and brake lights. Our 04 Safari Cheetah has never challenged me more to hunt down the issue. I’m normally pretty good at chasing down problems but this one is frustrating. The right amber and red brake lights flash perfectly, the left amber and red brake flash perfectly however the right ambers join in on the fun to drive me nuts. I have checked all related fuses, relays, all front and side markers work perfectly. Oh, the little turn signal bell works as it should with the right activated, when turning left it will sound at about every fourth flash! No leds lamps in the rear, I looked at the rear wire looms and no visible charring or discoloration. First to help me correct this gets a big attaboy Link to comment Share on other sites More sharing options...
Rob connors Posted June 25, 2021 Share Posted June 25, 2021 Usually when Turn Signals get weird it’s a ground problem if have found in the past Link to comment Share on other sites More sharing options...
vito.a Posted June 25, 2021 Share Posted June 25, 2021 On most of these motorhomes only the amber flashes for the turn signal. I would focus on the trailer 3-to-2 turn signal converter. https://www.amazon.com/56190-Powered-2-Wire-Taillight-Converter/dp/B004IYB968/ref=sr_1_15?dchild=1&keywords=trailer+turn+signal+conversion&qid=1624655338&sr=8-15 Link to comment Share on other sites More sharing options...
Ivylog Posted June 25, 2021 Share Posted June 25, 2021 X2 on a ground problem. Link to comment Share on other sites More sharing options...
Joel & Susanna Posted June 26, 2021 Author Share Posted June 26, 2021 Found steering diodes in line with the trailer / toad light socket with one of the diodes being bad. Problem solved. thanks folks Link to comment Share on other sites More sharing options...
waterskier_1 Posted June 26, 2021 Share Posted June 26, 2021 You have a ground problem in the bulb sockets. I'd start with the onery right turn. Link to comment Share on other sites More sharing options...
